2001 e350 quigley 4x4 v10
phdatsun
https://sandiego.craigslist.org/esd/cto/d/e350-ford-4wd-quigley-van/6558193296.html
2002 ford e350 van
cylinders: 10 cylinders
drive: 4wd
fuel: gas
odometer: 93000
title status: clean
transmission: automatic
type: van
Video walk around 9koboSelling my van. It got replaced with a motorhome. This van runs and drives great. 4wd shifts smooth. Suspension is tight. 12k pound hitch. Power windows and locks. Cruise control. It's a v10. Has 31" tires that are almost new. I was told it was a ex prosioner transport van because of this there is no inside door handle on the sliding door and it has holes in the dash from where things were screwed in etc. You could add one if you wanted. It has 200 watts of solar, a mppt charge controller, and good size power inverter, 50 amp shore power charger. I did take the 3 batteries it had and put them in my motorhome so you will need batteries. It does still have the battery that runs the engine. It has a simple wood interior. A fridge with freezer that is really efficient a toaster and microwave. With 3 good batteries and the solar with sun will keep the fridge running and allow you to use the appliances for weeks without draining the Batteries. I still have the rear bench seat it is easily installed and comes with it. Title in hand.
The bad:
This van came from the east coast so it is rusty and has some body rot. If you can't deal with rust doesn't not come look at it. The vent line from the gas tank drips gas when you fill the tank all the way up. I'm a horrible person I just let it drip and never cared about fixing it. It's not bad and stops dripping after a few seconds. It makes a few funny noises from time to time but other than that it works great.
xander69
