2001 F350 Lariat 7.3L Powerstroke diesel engine Crew cab with long bed with AT Overland Summit topper.$27,000
SequoiaOR
2001 F350 Lariat 7.3L Powerstroke diesel engine 205,000 miles. Crew cab with long bed
$27,000
The truck has been regularly serviced and maintained. I have service records in hand
Significant truck maintenance
148,000 miles
New water pump and thermostat
150,000 miles
New turbo up-pipes
152,000 miles
New alternator and batteries
178,000 miles
Front differential fluid change
182,000 miles
New battery cable ends, new carrier bearing, resurfaced exhaust manifold, new sway bar end links and bushings, new tie rod ends and drag link, new steering gear, new balljoints, new front leaf springs with 2” lift, new Bilstein 5100’s all around, 4 new 33" BFG KO2's
185,000 miles
Rear differential and transfer case fluid change, new ICP sensor, new brake hoses and left front ABS sensor
200,000 miles
New power steering pump and high pressure hose
204,000 miles
All new glow plugs, new valve cover harness/seals, new glow plug relay, new IDM
204,710 miles
Oil change and transmission service
2020 AT Overland Summit topper
Front sliding window
Driver and passenger Tern Overland Euro style windows with shades and screens
Roof skylight with spoiler, shades, screen, and lighting
Maxxair power roof vent fan
Amber led lighting on rear pillar
12 volt power system
Roof rack
Insulated liner (There is damage to one window cover from my pup.)
Additional 3rd AGM battery in bed for house power. Charges from alternator but disconnects to prevent drain on 2 starter batteries
Decked drawer system in bed
Diesel heater installed in bed, draws fuel from the main tank.
Current issues
Warped front rotors that need machining or replacement
Front hub vacuum seals leaking. Hubs need to be manually locked for 4WD.
Mhanks57
Any chance of getting some more interior pictures of the truck? If so you can send them to my cell instead of uploading here. You can respond to: 8zero4-59O-3Othree6 that’s a Virginia area code but I live in NW Montana. Is there any rust in the bodywork? Can’t really tell from the pictures. Also what kind of highway mpg with the AT installed. Thanks, Mark
SequoiaOR
I can absolutely send more interior photos. Do you have specific areas you would like to see?
There is almost zero rust. I'll send you photos of the one or two very minor spots.
I average about 12.5 mpg with daily driving but I haven't tried to figure the specific highway mileage.
WonaWarrior
