2001 Mitsubishi Montero Limited $8500/obo
DougL3NC
2001 Montero Limited 155K miles, White over Silver with Black Leather/Grey carpets. OME HD Lift, OME Nitrocharger Shocks, 265/75/16 BFG AT's (75%), Surco 40x60 roof basket w/mounts, and Class III Reese hitch.
Timing belt & tensioner, water pump, all pulleys and tensioner, plugs & wires, valve cover gaskets, coolant & thermostat, plenum gaskets, all 4 O2 sensors, and I'm sure of some other things replaced at 125K(over 2 yrs ago).
OME springs & shocks, both front hubs, front rotors and pads, and rear pads in August '10.
In-dash CD/DVD player and Pass. side rear cam seal replaced on 2/7/11.
Custom aluminum sump guard to be installed soon or come ready for install.
Truck runs great, pulls great, EVERYTHING works, and will haul 7 in relative comfort while getting 13mpg around town and 16mpg on the highway. MIL Light is on because I need to replace the thermostat...the ECU is stating that the engine is running too cool. For those of you that know Gen3's, you can laugh with me. That will be fixed before purchase, and seems to be a common issue.
$8500 or best offer. Open to trades, preferable VW Jetta or Golf Diesel MANUAL transmission only.
Goldenbora
