2001 Mitsubishi Montero Limited
swsuhovecky
145K miles. Clean title in hand.
$6,000 OBO - San Diego area
Have had this truck since 95K miles. Was garage kept before I purchased. Has been a great rig for mild to moderate trails/camping. 4WD works great. Low gear beeps while engaged (likely needs a solenoid replaced) but engages fine.
All maintenance is up to date (purchased the SUV with 95k miles):
~ 105k miles - timing belt & tensioner, water pump, radiator replaced.
~105k miles - transfer case, front and rear diff fluid replaced.
~115k miles - spark plugs, wires, valve cover gasket, intake plenum replaced.
Major suspension items replaced due to wear:
Steering rack
Front driver and passenger half shaft axles and wheel hubs
Front driver and passenger upper control arms
Sway bar end links
Offroad goodies:
Front and rear shocks and springs @ 105k miles with 2 inch lift (Old Man Emu)
Radiator, engine, and transmission steel skid plates
OME Rock sliders
The bad:
Paint oxidation on hood and roof
Oil leak at valve cover. Needs gasket replaced - slow seep
Front driver seat electrical - seat will not slide forward but all other functions work. Likely needs a switch replaced
sunnyaz
