Asking 7000, would consider partial trade for a 4 door tracker or sidekick, or maybe something else...who knows?
Build thread with more pics: http://www.expeditionportal.com/forum/threads/57048-New-Montero-Sport-Owner
2001 Mitsubishi Montero Sport XS. 124xxx 3.5 v6, 4wd, auto, cruise control, a/c, pw, pl, etc. I purchased it in the bay area from the original owners with 110k on it, it spent most of its life in new mexico. The previous owner had flushed all fluids (trans, transfer case, diffs, coolant, etc) before I bought it and had a stack of receipts and maintenance records. When I bought it I completed the 100k service including:
Timing belt and both tensioners
All four camshaft seals, front and rear.
Front crankshaft seal
All accessory belts and tensioner pulleys
Sparks plugs and wires (NGK)
Valve Cover Gaskets
Upper intake plenum gasket
Water pump (complete assy)
Thermostat and all related gaskets
I have also added the following:
ARB air locking rear differential, new bearings at the same time
On board air compressor for the ARB using a properly wired, filtered and regulated quickair compressor
Auxiliary electrical setup using a blue sea systems fuse block
Vibrant Air Filter setup to make room for the compressor
Aux air tank installed in rear quarter panel with custom bracket.
A cooler/Co2 rack replacing part of the rear seat.
A custom built low profile roof rack and fairing using Yakima feet
Custom built rocker panel guards
Custom built oil pan/front diff skid plates and transmission skid
Upgraded stereo with a alpine deck and infiniti speakers replacing all the factory units, ipod cable running to center console.
Rear cargo cover area mat made from rubber flooring
recent wear items:
New Costco battery with receipt
265-75-16 Falken Wildpeaks with 6k on them (5 tires)
Wiper Blades (Goodyear frameless style)
New headlight bulbs
Radiator Cap
I'm sure there is stuff I'm forgetting, but I have receipts from myself and the previous owner. This vehicle has been used for light off roading, I won't attempt to hide that. However it is also my family road trip and camping vehicle having completed three 2000 plus mile trips in the past 4 months, so it is mechanically sound and has been very reliable vehicle for me. There is damage to the passenger rear quarter just forward of the tail light. Clean and clear title in my name.
I can get more pics if you need.
Valve Cover Gaskets
recent wear items:
New headlight bulbs
Radiator Cap
