2001 Mitsubishi Montero
asuw07
Make: Mitsubishi
Model: Montero
Year: 2001
Trim: XLS (4.90 no LSD)
Mileage: 214k
Located in Glen Ellyn, IL
Selling this 2001 Mitsubishi Montero with some turn-key Overland specs. I’ve owned the vehicle for 5 years. Originally purchased in Arizona with 136k miles on it and brought it to Illinois for my Overland project / build.
Clean IL Title.
$13,000 is the asking price. Open to hear your offer.
Notable Repairs and Maintenance:
* Timing Belt, Water Pump, Timing Tensioner
* Windshield and Windshield Rubber Gasket
* New Transmission (from a used Montero); Trans Fluid Flushed & New Filter
* Head Gaskets
* Fuel Filter and Fuel Strainer
* Lifters
* Valve Covers & Gaskets
* Front / Rear Cam Seals
* Spark Plugs, Spark Plug Tube Seals & Spark Plug Wires
* Intake Gaskets
* EGR Valve & EGR Solenoid
* High Pressure Oil Hoses
* Oil Pressure Sensor Switch
* Power Steering Rack
* High Pressure Power Steering Hose
* Bushings for Upper / Lower Control Arms
* Front & Rear Sway Bar End Links & Bushings
* A/C Compressor
* Serpentine Belt, Belt Tensioner & Pulleys
* Front & Rear Differential Mounting Bushings
* Front Wheel Hubs
* Front ABS Sensor (passenger side)
* Brake Bleed / Flush
* Radiator Flush
* Neutral Safety Switch
* 4WD Vacuum Solenoid Switch
* Front / Center / Rear Differential Oil Change
* Front CV Axles
Add-ons / Upgrades:
* Remote Start
* OME HD Lift
* OME Shocks / Struts
* BFG KO2 285/75/16 (including the spare tire)
* Australian Spare Tire Lift Plate (to clear the rear bumper for the larger tires)
* Front Runner Slimline II Rack
* Snorkel
* ARB Differential Breather
* Skid Plates (Bash Plates) from Adventure Driven Design
* LED Offroad Lights (2 on each side, plus 1 in front, and 1 in the rear)
* LED Headlight (lamp bulb conversion)
* Custom Tablet Mount for GPS / “Infotainment”
* Trailer Hitch w/ Recovery Point
* National Luna Dual Battery Setup w/ Controller
* 75 Ah Batter in the 3rd Row Seat Storage
* Midland GMRS Radio w/Antenna
* Pioneer Head Unit
* 8" Sub w/Amp
* Front / Rear Dashcam
* Horn Switch for Cold Nights (Montero’s have an issue where the horn pad touches in cold weather)
* Heated Seats (aftermarket, XLS trim did not come with this option for 2001)
* Custom Fit Cover King Seat Covers
* Custom Rear Tray Setup for Fridge (will come with the table and Coleman grill, Harbor Freight Air Pump, no fridge [I'm keeping that for the next build])
* Cabin Air Filter (comes with 2 new filters)
* KATS Lower Radiator Hose Heater (for cold winter starts)
Additional Items / Parts Included:
* Original 4 Speed Automatic Transmission (needs a rebuild)
* 3rd Row Seat (removed for the dual battery)
* Original Power Steering Rack (needs a rebuild)
* Original Front Upper & Lower Control Arms (needs new bushings)
* Original Retractable Rear Storage Cover
* Misc. Parts
  • Cupholders
  • Rear Door Tool Storage
  • Rear Washer Reservoir
  • Fuses / Relays
  • Center Console Lid
  • Air Intake Box
  • Misc. Suspension Components
  • Plastic Body Panel Clips
  • Front Driver ABS Sensor (purchased when replacing the front passenger)
