2001 Tacoma - MD - 3RZ 5spd Twinstick Custom Flatbed
zaroot
$20k: Includes Iceco fridge slide, 100aH lithium house battery, side box, and like-new OVS Bushveld II hard shell tent in the price.
$17k: Truck and custom rack/swinger/side gate
Would also entertain a partial trade + cash for a stock 1st gen tacoma. Ideally a 3.4 5 speed 4x4.
2001 Toyota Tacoma Xtracab 2.7 4wd 5spd
221k miles
Majority of the work has been done within the last 3 months
Frame was replaced by Toyota in 2016
Engine
New alternator and power steering pump
All Belts, rad cap, and thermostat
New plugs
EGR service and new VSS
IAC valve
Oil & filters
Drivetrain
Fully rebuilt W59: New shift forks, input shaft, bearings, synchros, seals, and fluid
Twin stick transfer case
New extended travel CV shafts
New Aisin clutch kit
New spicer rear carrier bearing
Suspension
Toytec Boss 2.0 Aluma Coilovers
JBA UCA
New Toyota UCA throughbolts
New Toyota LBJs and hardware
New Moog sway bar bushings and links
OME Dakar rear leafs with new bushings
New Icon AAL packs and U bolts
OME shackles with Greaseable bolts
OME rear shocks
Front end alignment
Allpro front bumper
Dark Defense 3.5” LED pods with harness
Smittybilt 8k winch w/ Anderson connector
100’ of synthetic line
New aluminum hawse
LROR gas tank skid
New gas tank straps and hardware
New floor mats front and rear
New Toyota battery hold down
5th gen 4R Panasonic battery
Custom rear dove tail bed and removable tent rack via 3/8” Gr8 bolts
1.5” DOM fenders with diamond plate infill
Custom mud flaps
Large passenger drop side toolbox
2ga battery cables to rear
Marine battery disconnect switch
Spare battery voltage sensing relay for charge while driving
Custom TIG welded aluminum drop side gate work station on brass bushing hinges and lock pins with cable stays
Iceco refrigerator slide tray
Custom swing out tire carrier
Ruffstuff latch and pins
Heavy duty spindle with tapered roller bearings
33x12.50R17 nitto spare
(4) brand new 17” Icon Nuevo machined aluminum wheels with Kenda R/T 601 33x10.50R17 tires
Splined lug nuts with extras
Well built rig. Half the price of a built out 3rd gen, and better looking IMO. Windshield has a crack, that’s about it
21161 Maryland
Clean title
Will hold with a non-refundable deposit
zaroot
Would also consider the following partial trades with cash on your end:
Kubota B, L, BX 4wd tractor
FWC Hawk truck camper, older (pre 2010)
Lincoln Ranger GXT 250 welder
Toyota based crawler (geared, locked, dual cases, caged, etc.)
sunnyaz
