2001 Toyota Tacoma DC - 173,856 miles
Nicklovin
$14,500 obo
Clean Title
Located in Huntington Beach, CA, USA
This is a 2001 Toyota Tacoma 4x4 with the 3.4 V6, 173,856 miles and a clean title. I used it as my daily driver and to go camping since I purchased it in 2019 at 150,622 miles. I love this truck, but I wanted something bigger and I bought a tundra. It has an eye-catching two-tone paint job using Raptorliner, which is a brand of bedliner.
Suspension wise it has Icon 2.5 extended travel coilovers and Solo Motorsports uniball upper control arms in the front, and in the rear it has Icon 2.0 shocks with reservoirs and Dakar leaf springs. The tires are like new with less than 3000 miles on them, Falken Wildpeak 255/80/17 on 4runner wheels; they are skinny 33s. It also has a Softtopper on the bed, tinted windows, and a bluetooth radio.
When I purchased it I immediately replaced the timing belt and water pump. While doing that I also cleaned the throttle body and MAF sensor, replaced the spark plugs and wires, throttle body gasket, and the valve cover gaskets. I have also upgraded the brakes to Powerstop drilled and slotted rotors. Some other major maintenance I have done is I replaced the lower ball joints with new OEM ones, OEM steering rack, a new starter, and new cv axles. It does need the valve cover replaced on the passenger side again, it has a slight leak in the corner. Other maintenance is listed below.
Major Maintenance Records:
  • Timing belt at 143k
  • Valve cover gaskets
  • Spark plugs & wires
  • Rear brakes 156,337 miles
  • O2 sensor Bank 1
  • OEM Steering Rack & tie rods at 164,414 miles
  • OEM Lower Ball Joints
  • NAPA CV Axles
  • Starter at 173,329 miles
  • Battery replaced a month ago
  • Alternator, power steering, and AC belts replaced 173,490
I have a folder full of receipts for all these maintenance items, as well as others. Oil change is done every 5,000 miles. This truck has been great to me, it has helped me make many memories on road trips.
gp01
