2001 Well equipped 7.3 Sportsmobile $59,600 Las Vegas
docmaas
http://www.rvtrader.com/listing/2001-Sportsmobile-E350-112026040
2001 Sportsmobile E350 , E-350 Extended body, GVWR 9,400, 7.3L turbo diesel power stroke 215 HP, 4X4 conversion by Quigley, 3.6 KW propane generator, 3,000 watt Xantrax 3.5 inverter (25 amp), microwave, 4+ CU FT 3 way fridge (AC/DC & prppane), 6 6-volt house batteries (les than 1 yr old), 2 12-volt chassis batteries (less than 2 yr old), 7-70 watt Kyocera solar panels, 2-20 gal fresh water tanks, 12 gal gray water tank, 6 gal black water tank, frame mounted 18.9 gal propane tank, WC with shower, roof mounted 15,000 BTU Penquin AC, Rancho adjustable shocks, Reunel solid stainless steel front bumper with high lift jack and ax, 20,000 lbs Reunel rear bumper with hitch receiver and tire mount, 8-55 watt top mounted flood lights by Per Lux, individual control of lights with master controls, 2 Hella 25.000 volt off road driving lights, Warn 15,000 lb front mounted winch with the remote, 3.5 CF/hr 12 volt air compressor, 2 28 gal Trax UFS fuel tanks. Ready to tow or be towed. Original cost $134,000 $59,600.00 7026061647
No connection
DanoWall
