Well, turns out the PO wasn't exactly truthful and I didn't make a very good buy on my 2002 Montero
The check engine light is on with a P0446 code. Took it to the shop where they changed out an emissions solenoid but the Check Engine Light stayed on. After several attempts to fix the problem, they found out that the ECU was bad. Bummer. I can't pass emissions with a check engine light on.
I found a used ECU on eBay with the ignition, key and immobilizer. Has anyone done this repair? Any advice? Does the computer need to be reprogrammed?
http://www.ebay.com/itm/361310759557?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
