Offroadmuch
Any update?
Did you ever crank it for a bit then pull a plug and smell for gas? Also smell the cylinder (use a piece of hose if you can't get your nose close enough). I know you got fuel back by the tank (your gas shower) but that doesn't mean it's getting into the manifold. You need to determine if your injectors are firing. If you have spark, and fuel in the cylinders, that is good info to have for next steps.
Also, can you confirm that your check engine light is working (not removed or burned out)? When you turn key on your cluster will illuminate in diagnostic mode, everything should light up, do you see the check engine light at that time?
Check your MAF plug, maybe it got disconnected somehow.
And you said that you tried to hook up a computer to read codes, but you couldn't communicate with trucks ECU, but you replaced the ECU with a new (refurbished) one. Can you talk to the computer now?
I would have to look for that valve. I don't think that I have seen it. The car just turns and turns, no sputter.Also, does the Gen-3 have a Schrader valve under the hood on the fuel line so you can check pressure? Does the truck sputter at all, or is it just a dead crank when you turn it over?
