2002 Toyota Tundra Access Cab 4wd Limited
ThorH
2002 Limited AC 4WD
172k miles
Bilstein 5100's
OME 885 Front coils
Light Racing UCA's
Wheelers Add A Leaf with Air Lift bags
Diff drop
Total Chaos Rack Bushings
930 CV boots
Snug Top Hard Tonneau Cover
Bed Rug liner- been in there since day 1. Not a scratch or dent in the bed.
285/75-16 BFG KO2's with about 20k miles
All Mobil 1 oils
Front brakes updated to later Gen1 calipers
New Windshield
$9900
Thor
ThorH
We might be able to work something out. Have relatives in Nashville. Been wanting to get out there!
ThorH
Here you go!
4joggin
Hi,
Any ding or dents in the cab? How is the interior carpet?
Does it use any oil between oil changes? Any oil leaks? Diff, Transfer case and or transmission leaks?
Secondary air pump issues?
Paint faded/ cracked?
Dash condition?
All instruments work? Dash lights work?
When was the timing belt done?
Possible airport pick up?
Thanks!
Steve
ThorH
Couple of small dings (16 yrs old). Carpet is in good shape. Doesn't use any oil. No leaks. Oil is has been changed every 5k along with a drain and fill of the tranny with each oil change. So about 4 new quarts of ATF each oil change. Was told TB was done at 100k when i bought it, but there is no sticker to back that up. Was going to do the belt at 180k. Paint is is great shape. Dash is beautiful. No known air pump issue. Everything is operational. Would love to pick anyone up at the airport.
xander69
