2002 Tundra 4x4 SR5 TRD
speedtre
116K miles and extremely clean. No dents, great paint you could eat off the engine. Power everything (except seats), cold A/C, AM/FM/CD, Auto, 4X4, tow package, limited slip differential, SR5, 4.7 V8, ABS, TRD, tinted rear windows, sliding rear window, cruise control, tilt steering wheel, remote key fob (but the key chain loop is busted), Line-X spray in bedliner, center console, bench seat (6 seat belts total), very clean cloth upholstery (never smoked in), heavy duty rubber floor mats (factory carpeted mats if you want them as well) front and rear. Clear title in hand. Southern truck, no rust issues at all. Completely clean car fax report. New timing belt @ 90K miles. Within the last 10K miles ago I had new Bilstein 5100 shocks, new Pro Comp 8069 aluminum wheels (with new 285/75/16 Nitto Terra Grapplers), a one inch block in rear (to level the truck with the new shocks), nerf bars, a differential drop for the front drive shafts (to accommodate the taller 5100s) installed and new brakes front and rear. All work was done by ACC, Toyota Truck and Land Cruiser Specialists.
http://www.acctoyota.com/
They also changed the oil (synthetic and I've had it changed several times since then) in the engine and both differentials and gave the truck a thorough going over and said it's in tip-top shape.
Here is a link the carfax I pulled on it today....notice the timing belt was changed when it was serviced on 05/31/2006.
http://www.carfax.com/viewEmailRepo...flRY7u8cknIGhX6ndWRqzR9bDgDaCTSi3&language=en
I've attached some pics and I have a PDF of all the receipts of any work I've had performed while I've owned it. The only receipt I couldn't find was from the tires and wheels. They were purchased online and sent to ACC to be installed so I never got the physical receipt, just an e-mail receipt I can't find. If you are interested in the truck, let me know and I'll forward the receipts to you.
I'm going to post it on craigslist for $12K OBO. It's not a desperate sale, so $10K won't do it, but half-way between those two numbers will....:)
speedtre
Not surprised at all! That is a lot of truck for the price.
Maybe I should have asked more....DOH! ;)
It's a great truck and the owner-to-be is excited about getting, so I'm happy. I will miss it though... :(
Houie
