2003 4x4 Ford E350 - 7.3 Power Stroke - Camper van/truck Ex Ambulance - 72 000 Canadian $.
TomKro
Real 4 season 4x4 camper/adventure machine - great for ski trips, bike trips, hunting etc.
Fully off the grid setup great for remote places
Tested in -30 degree Celsius weather conditions.
ENGINE/TRUCK/DRIVETRAIN INFO:
130 xxx km on the engine that has been rebuilded at 85 xxx km.
Upgraded - single shot injectors
Stainless steel up pipes
Kc turbo - wicked wheel
DP tuner with 4 different tunes
HPOP Crossover line added for smoother engine operation
Transmission rebuild, upgraded at 85 xxx km when converting to 4x4.
Front/back axle, engine are from F350 truck with 3.73 gear ratio.
All the upgrades mentioned above make up really great gas mileage 12-15 L/100km. (19.6 - 15.6)
Custom 4x4 kit, similar to Ujoint about 6in lift - 4hi, 4 low, 2wd, manual Warn hubs.
33 inch Patagonia tires.
Secondary 200 litre fuel tank and Raptor pump - truck can be run on Waste Vegetable oil or similar alternative fuel, or can be used for regular diesel. Very long drive range. Original tank is 130 l. ( 350 litres of fuel capacity )
378 xxx km on the original ambulance body
Remote fob - Crime stoppers with remote start.
Steel front, rear swing bumper - one side carries spare tire, other fits 2 x 20 litres jerry cans.
12 000 lbs winch with synthetic rope, remote control
2in hitch at the back + trailer brake controller
Backup camera
Many auxiliary lights all around - front, back, sides.
Onboard Compressor to inflate tires.
Custom aluminum roof rack + side ladder
Kilmat sound deadening in cab installed.
CAMPER INFO:
Crestline ambulance body - 2in insulation + every cavity was insulated with wool
2x Self heated lithium Canbat LiFePO4 100ah - total 200 usable Amp Hours
3x 100W solar panels
DC-DC Renogy 60A charger - truck have 2 alternators - charging when driving
Diesel heater
Memory foam mattress
12V medium size truck fridge
Compostable toilet with separate compartments.
Full size shower.
80 litres fresh water tank, 12v marine pump, gray water tank.
2x Water heater - water is heated when driving with coolant + another (Webasto) marine diesel heater for heating water when stationary - also preheats engine coolant.
4x security cameras.
Lots of storage all around.
MaxAir fan.
2000 watt inverter - many electrical outlets inside.
Swivel seats from Mitsubishi Delica
Manual rv steps on side.
Electric awning.
Outside outlets for water and 110V, when stationary parked.
Roll up/down privacy curtain, blackouts for windows.
Registered as RV.
Truck is very well maintained, took us on many trips around BC, to Baja, USA etc.
Oil changed every 5000 kms.
Lots of parts and sensors changed as needed and as a prevention.
Price is 77 000 Canadian $. Open to reasonable offers.
Contact me at krenda@gmail.com
gp01
