2003 Bigfoot on E450 Chassis with V10 Triton
Jaredsmits
2003 E450 with Bigfoot 27’ Coach
  • 2010 Front Clip
  • Weldtec Designs 6” lift kit with Fox Shocks
  • Fox Steering Damper
  • Hellwig Sway Bars front and rear
  • Blue Ox Rear Trac Bar
  • Additional Transmission Cooler with Spin on Filter
  • Banks Headers with heat wrap, Custom stainless 4” exhaust from headers back
  • Transmission completely upgraded with all Billet parts and valving. Made to be Bulletproof.
  • Custom 19.5” aluminum wheels with 14 Ply Load Range G Continental Tires (new)
  • Aluminum roof rack Full Length
  • 1200W solar panel system. Commercial Qcell panels with Outback controller
  • Roof completely tore down and rebuilt with stainless steel cross members. Plywood, ice and water shield.
  • Cab interior tore out and sound proofing installed, new carpet, husky floor mats. Doghouse has extra heat shield and sound proofing from engine.
  • Backup camera
  • Tire pressure monitors
  • All New double Pane windows in Coach
  • Interior completely re done with paint, ceiling vinyl, lighting, flooring, cabinetry, dining area, upholstery.
  • All new plumbing fixtures inside and out
  • Rear door installed with steps from bedroom.
  • (6) extra heavy golf cart batteries
  • Custom high end MB quart sound system in coach and chassis. With apply CarPlay and Bluetooth
  • Exterior caulking all removed and redone with Dowsil professional silicone
  • LED lights inside and out
  • Much more done to this unit, made to be completely off grid and boondock
  • Comes with all electrical adaptor for 15, 30, and 50 amp plugs. Comes with 130’ of 10 gauge cord. 75’ fresh water hose. 20’ extreme sewer hose.
  • Has on board air compressor for air bags in rear. Also air line hookup to air up tires in case of flat tire
  • Comes with hydraulic jack, tools, RV accessories
  • Endy mattress (new)
  • (3) new remote control Maxx Fans (automatic opening and closing to operate during rain.
  • Dining room chair directly bolted to frame for child seat
  • New Tie Rod ends, wheel seals, draglink ends, ball joints
  • 55,000 miles
  • Originally from Arizona, zero rust
  • Front mount receiver, rear receiver
  • All oils are new and Amsoil, all filters are new.
  • Selling as we have another baby coming, building house, lifestyle change
  • Built to keep forever, no expenses spared, everything thought off for camping off grid, travelling around North America long term
  • Custom Cedar exterior shower platform with curtain
  • Additional cooling fans installed on fridge for when running off propane
  • Propane line and accessories so you can easily hook up 20, 40 or 100 lb propane tank to RV for extended stay. Also feed for BBQ off on board tank
  • Comes with Camp Chef Pro 16 BBQ
  • Soft start on air conditioner so can run on 15 amp, or Honda 2200W generator
  • $128,000 US or best offer
  • Contact Jared at smitsconcrete@mail.com or 519-521-5443
Jaredsmits
No. It is the V10 gas triton. Which I prefer as I have found travelling across Canada, that diesel stations are far far fewer than gas stations. Also from what I have found for fuel mileage it’s not terribly different. I’m averaging 23L/100km. My Isuzu NRR work cube truck with 5.2L I4 is about the same weight and size. averages 19L/100km. My Toyota tundra with 4.7L gas towing 26’ enclosed trailer same combined weight I’m at 21L/100km
Also repairs or worst case replacement are much more reasonable if you ever need them on the gas versus diesel.
MsRandiCook
Jared,
Thank you so much for the update. I'm wanting a diesel as here in the states, we have diesel everywhere. Best of luck on the sale. I would suggest you put the camper name, age and list the engine in your beginning of add...
Cheers,
Randi
Jaredsmits
No problem. I would maybe reconsider the diesel engine. I come from a family of only diesel vehicles from our Mercedes diesel cars, to dodge diesel trucks, to my work cube trucks.
It was hard me to consider a gas engine in a large vehicle but when I worked out the numbers on above mentioned points the gas engine was the best decision. If it could have been an inline diesel option such as Cummins or Isuzu I’d consider it but not any V engine options in the Fords and Chev
Jaredsmits
2wd
Fuel tank - 55 gal.
Propane - 21 gal.
Fresh water tank 63 gal.
Black tank 32 gal.
Grey tank 30 gal.
Reminded genset and instead use Honda 2200. This is quieter because it’s not attached to the rig. Also put a soft start on AC so it will run on Honda 2200.
gp01
