2003 Chevrolet Astro Van AWD - Argentina
zchan88
$8,500 USD
≈ 120,000 Miles
4.3 L V6 Engine - MPFI
Pictures
Modifications
Comfort:
  • Sleeping platform – 48”x75” RV mattress on a custom built pulley system.
  • Custom kitchen – Unit contains a 40,000 BTU camping stove and cutting board, along with storage space for kitchen supplies. The unit is stored in the vehicle on 1” castors and deploys collapsible legs when in use.
  • Retractable awning – 8' ARB awning with mosquito net
  • Fridge/Freezer – Engel MT17
  • Propane tank – 20 lb bulk tank with securing strap
  • Water Reservoir – 7 Gallons with hand pump
  • Auxiliary Battery – Optima 31T deep cycle AGM battery. Powers stereo, amplifier, refrigerator, GPS, and inverter.
  • Battery charging unit which allows plugging auxillary battery into 110 VAC outlet
  • Inverter – 1000 w DC to AC modified sine inverter
  • Amplifier – 5 Channel amp (4 being used) powering a component system in the front and 6.5” spearkers in the rear.
  • CD Player – JVC with usb and two auxiliary inputs. The rear aux input is wired to the rear compartment of the van as part of the entertainment system.
  • Interior Lighting, Reading Lights x 2, Side door, and Rear Hatch
  • Privacy curtains
Security:
  • Zombie Proofing – Partition from Cargo van installed. In addition, expanded steel welded to the interior of the car over the five windows in the rear compartment.
  • After market car alarm
  • Door lock disconnect switch to isolate rear compartment if someone were to break into front compartment.
  • Locking gas cap
  • Starter kill switch
  • Hide a key lock box mounted to underside of van
  • Full size spare tire
  • Exterior lighting – While discretely parked allows visibility outside the van and passive signaling that the van is occupied.
  • Hella Fog Lights
Structural:
  • 4″ Suspension Lift – Kit purchased from overlandvans.com
  • Upgraded tires -Hankook, 265/70/16
  • Custom cabinetry made for aux battery, tools, shoes and miscellaneous items.
  • New floor – 1/2″ ply wood with industrial floor mat
  • Roof rack – Stock roof rack obtained from a local U-Pull-It.
In addition the word document below contains a list of all miscellaneous items which are included in the purchase of the vehicle. These items will make for a more comfortable and safer journey.
Additional Items
View attachment Additional Items.doc
Maintenance Records
View attachment Maintenance Records.xls
We would like to sell the car in May at the end of our journey in Argentina. Contact us with any questions at anywherethatswild@gmail.com
flipstick
