2003 E350 7.3 Timberline 4x4
Rider4
2003 E350, 7.3 Powerstroke Diesel, Timeberline 4x4 conversion, 211k miles
This van is in great shape and drives amazing and will take you pretty much anywhere you want to go. At highway speeds the van holds the road perfectly with no pulls, wobbles or any nonsense. Van has a modular type build on the inside and was designed as a mobile workstation and weekend camping rig to haul all your gear. Build details are below. I have paperwork for all the work completed on this build. I drive from CO to CA with this van and would not hesitate to drive it on any long distance trips.
Interior:
Fully sound dampened and insulated top to bottom, front to back.
New cushions that make up rear seating and complete the bed.
Heavy duty RV specific rubber flooring attached to ¾ subfloor
(2) 100w solar panels
1000w inverter
200amh battery
Amazing sound system (see pic for detailed list)
Table (in pics) sits on the rails to form the sleeping area
Seats are new and from a 2014 (power and lumbar)
Exterior:
2014 Front end conversion (update)
4 corner rock lights (lightforce)
Front LED bar mounted in bumper
Roof rack with ladder
New Goodyear Duratracs
Engine/Mechanical
Timeberline 4x4 conversion completed in 2018, Timberline installs a new trans when they do their conversion and all was done at 174k miles
New Spoologic stock plus turbo
New fuel bowl (they all need it as some point) this is a complete replacement and added the flexible fuel lines since stock are a weak point. Also replaced the following since it's all right there:
New bellowed up pipes
4” down pipe
Agile tuned Fox 2.0 shocks all the way around.
Located in Durango CO. $32,000
SilverForkPhil
Interior:
1000w inverter
200amh battery
Exterior:
Engine/Mechanical
4” down pipe
I
Interior:
1000w inverter
200amh battery
Exterior:
Engine/Mechanical
4” down pipe
Is van still available?
Phil
sunnyaz
