2003 Ford E-350 Quigley 4x4 Ambulance Camper Van For Sale
Amboater
2003 E-350 4x4 Ambo
Charlottesville, VA
$55,000
For sale here is an extremely unique Adventure Van: A 4X4 Ambulance!! I have spent every weekend for the last 5 years building this thing out and no detail has been missed or expense spared. Its been an amazing project but its time for me to pass the torch on to someone else to continue it from here. Here are some highlights of the build:
135k Miles
POWERTRAIN
2003 Ford E-350 7.3L Turbo Diesel
Quigley 4x4 Conversion
Hydra Tuner with custom tunes for Dail Driver, 60 Mountain, and 80 Mountain
New stock injectors installed in 2022 (less than 10k miles on them)
4" exhaust upgrade with Sinister Diesel exhaust tip
Custom Cold Air Intake Massive Filter
Wicked Wheel 2 Turbo Wheel upgrade
2006 F150 Transmission cooler install (dropped trans temp down to 145 degrees!)
Diesel gauges for Boost, Trans Temp, and EGT
2 Motorcraft 850 CCA starting batteries less than a year old
CAB OUTSIDE
Black Billet Grille
MOVE Offroad Bumper custom welded and powdercoated
Two amber Fog lights in bumper
126w LED light bar in bumper
300w LED light bar on basket
40w Ditch lights mounted on basket
Custom modified cargo basket over cab
Side mirrors replaced in last few years to new units
Windshield replaced 2 years ago
New windshield crowl
100w Solar panel in basket
12v AC unit in basket
gas can and leveling blocks
CAB INSIDE
Entire cab insulated with a layer of Kilmat and layer of closed cell foam
New carpeting installed
Sony stereo receiver with Carplay and backup camera install
Ford Van center console added and insulated on backside
Engine doghouse fully insulated with Kilmat
Both doors fully insulated with Kilmat
Front seats replaced with new 2008 model Ford Vinyl seats
New passenger seat belt assembly
WHEELS
Wildpeak AT tires and Superspring suspension lift on rear
Two new rear wheels and new hub on drivers rear
Matching spare tire and wheel
BOX OUTSIDE
Shelves built into all compartments
Maxxfan RV fan installed in roof
Teak Boat decking on entire roof
Entire underbody sand blasted primed and painted
Side step added to side door
Rear door latches replaced with new latches
All 3 Box doors refurbished with closed cell foam and new foam block
BOX INSIDE
31" Computer Monitor/ TV on swivel mount
Full size slat bed/ couch
Large 12v Refrigerator
2000 kw Diesel Heater
8000 BTU 12v mini split AC runs off house batteries
Gym matt flooring
Entire interior decorated with peel and stick wood wallpaper
Fold up table, 5 ft long and stows at only 1/2 inch
ELECTRICAL
All original Ambo wiring and circuit boards completely gutted from box and cab
2000w inverter
60A Charger
2 X 206 Ah Lithium Batteries
Fuse box
Switch panel
Relays, Breakers, Fuses on everything
WATER
23 gallon Fresh water tank
Tankless Propane water heater
20lb propane tank
And More!
Over 2,000 hrs of labor put into the build over 5 years. Starts every time, runs great and is ready for your next adventure!
sunnyaz
