2003 Ford E450 Wheeled Coach won't start.
AmberLamps
Ok so I have a question. Is there some kind of OEM anti-theft or starter disconnect that comes on 2003 E450 Wheeled Coaches? Maybe a known fix for when you disconnect all the batteries for a time and then reconnect them but it won't start? All the lights come on the dash when I turn the key, batt says 12v with fluke but it won't even attempt to turn over or start. I've reconnected 90% of the rear box wiring, leaving out the two amplifiers and wiring for the flashers as well as some comm cables that were for the radios. It's a temp fix as I'm moving the rig to another location to work on it so just trying to get it to start up at this point.
It has 2 batteries (I've found) - main one under hood and secondary behind passenger in exterior cargo bay. I've tried starting it both with and without the secondary connected.
From my understanding, the majority of the wiring in the box shouldn't interfere much with ignition? I'm not hearing any clicking for it trying to turn over.
