Ajohnson15835
Craigslist ad-
https://sfbay.craigslist.org/nby/cto/d/petaluma-2003-ford-ranger-xlt-23l-4cyl/7595833457.html
Price listed OBO
The truck:
2003 Ford Ranger XLT 2.3L 4cyl RWD Automatic, 202k miles
Clean Title and Carfax
Asking $8,500 OBO
Currently located in Petaluma, CA
Features:
-power windows
-power locks
-3 keys, 2 fobs (1 chipped ignition key, 2 door keys)
-2 camper shell keys
-UWS truck tool box (2 keys)
-wireless apple carplay/android auto touchscreen stereo
-premium speakers, pioneer brand 4 set
-2 dual usb charging ports (one shows battery voltage
-designer magsafe wireless charger
-all led lights, (front, rear, interior)
-48in led lightbar
-offroad bedlined front and rear bumpers
(2 recovery shackles on front)
-boar offroad 9600lb synthetic cable winch
-tow hitch and detachable offroad shackle
-bedlined low stripe for chip protection
-general grabber AT2 offroad tires, M+S
-rare camper shell with lumber rack, side and cab sliding windows, screens, and blackout curtains
-custom wood bed cabinet/frame with 2 compartments
-custom walnut wood center console top
-custom redwood wood cargo organizer behind seats (i am a furniture maker)
-comes with jumper cables, tree hugger recovery strap, full size spare general grabber AT2, spare tire change kit/lowering tools, and detachable tow hitch recovery shackle.
Recently replaced and upgraded:
-full synthetic Amsoil swap (differential, & engine) 20,000 recommended change, i did every 8,000 since owned
(Full synthetic trans fluid not AMSOIL)
-k&n cold air intake (reusable filter with recharge kit)
-new upgraded bilstein shocks
-new upgraded heavy duty leaf springs
-new upgraded XL AC system (blows cold), condenser and compressor (whole system)
-new heater core
-new cooling system (water pump, radiator, hoses, reservoir tank, thermostat)
-new fuel pump
-new coil springs
-new black american racing Outlaw 2 15in wheels
-New upper/lower control arms and bushings
-new upgraded dynaflow stainless exhaust (full system)
-new sway bar linkage & bushings
-new upgraded high performance Powerstop red disc brakes with ceramic pads in front and brand new Powerstop drums & pads in back
-new wheel cylinders and bearings
-updated new ECU (reprogrammed by ford)
-almost all new sensors all around
-new tensioner pulley & belt
-new alternator
-bee ignition coil, spark plugs, and wires
-new upgraded yellowtop deepcycle battery powers all accessories
-new black headlights and grille (led conversion)
-new window vent protectors
-new black plush carpet
-new black headliner
-black motomaster rubber off road floor mats
-new upgraded soundproofing/insulation in cab (whole cab lined, kilamat brand)
-new rear differential gasket/pan (fresh fluid
-new trans gasket/pan (fresh fluid)
Just had it professionally detailed!
This truck is a rare find being a step-side with a SUPER rare specific camper shell. (Took me 3 years to find it!)
It gets wonderful gas mileage and can hold its own on the highway cruising at 75-80 no problem!
With the winch & tires Ive never had an issue getting out of most situations.
I had the engine checked and pressure tested by my mechanic and was told it could last at least another 100k before needing a rebuild! (No head gasket issues for you!!!) The trans is a bit sticky in between 2nd & 3rd, and a little lag occasionally when shifting to reverse, but after 3 different trans shops checking it out i was told it wont get worse and has at least another 100k on it!
This truck is absolutely bombproof with great gas mileage, if you do the 2 upgrades i had planned to (lift & tires) this thing would be a lifetime daily offroader!
Future upgrades that are easily done yourself that i had planned to do:
-$420 4in/2in WULF lift kit (spindles and rear shackles) doesn’t change any geometry and maximizes ground clearance/tire size
-$900 falken wildpeak 32in tires (after lift)
