2003 Garrett Mobility Trailer
weaponxarmory
Bought this trailer a couple years ago. The chassis is steel and the box is aluminum. I separated the two and had the chassis sand blasted and CARC'd again. I put the box back on and had them CARC the box with the exception of the bottom of the box which is aluminum. The inside is just standard exterior paint from lowes and is a lighter shade. All of the wiring to the light work. Replaced the ones that weren't working. The wiring is 12 volt 7 way, will fit standard civilian trucks. Has wall outlet inside and a covered port on the outside to connect a drop cord to provide electrical to the inside of the trailer. Two gas can holders, a toolbox, and a spare tire holder on the tongue side. The taller side has a window that opens up and a fold down ledge that folds out to the inside as a sort of table. Tires have great trend, side walls a little cracked but ready to pull. There is a Kobalt basket system over the window to store small odds and ins. Opposite side is a make shift wooden....contraption...I built to throw gear in and close the lid. I threw some 3/4 plywood down on the floor and stapled some thin carpet to it. Also has stabilizing jacks for the corners and one for the tongue. Hitch is 2" ball but also has a pintle that you can change it to.
Dimensions: 98″L x 84″W x 96″H
Empty weight: approx. 2,400 lbs.
Gross weight: 10,000 lbs.
ASKING 4,500 FOR THE TRAILER
For any more details or more pictures please email me: weaponxarmory@gmail.com
Falcon NC
weaponxarmory
I believe they are 14x25 and 12inches down. They work on a track system. I believe the weight limit per basket is 25 pounds. But they sell different attachments for the track and it will hold a lot of weight. I used it for paper products and kitchen items for camping/tailgating.
