2003 Hummer H2 and Custom square top Richmond Va 32,500 OBO
Boucher
I am selling my 2003 Hummer H2 and custom offroad trailer
Vehicle 2003 Hummer H2 artic white with Tan interior
Interior
New Headliner
Apple Car play
Video rear view mirror
Custom Autometer gauges with Pod (2 gauges to see oil pressure and oil temp as I don’t trust the factory gauge)
Front Custom power panel – works extra lights
Rear custom power panel – works inverter, fridge, and compressor
  • Kickass slim line 12V 120 AH Battery
  • 1100 Watt inverter
  • ARB dual compressor
  • CTEK Dual input charger
  • Smitty built fridge
The Interior is in excellent condition no rips have an optional third-row seat for it too.
Exterior
Defender Roof Rack
Roof mounted Solar panel for battery tender
100W Roof mounted Solar panel for the rear battery system
Pelican case storage on the roof rack
Light bar
Retrofitted LED lights where old Daytime running lights were
37-inch tires (6 months old)
4.88 Gears (6 months old) improved fuel mileage and can actually have cruise control work as it should
Up down air system
Driveshafts new Spicer u -joints and balanced
Kryptonite upper control arms and Ball joints, lower ball joints, idler arm, and tie rod ends.
New front hubs
Larger transmission cooler
New radiator within the past year
Removed Fan clutch and added the chevy mod with electric fans 2-speeds works of the computer
REDARC trailer control
New rear lower control arms
SPOHN Performance Tubular Adjustable Panhard Bar
Engine Has 180K on it
6 months ago, I installed a new Melling oil pump and while I was in their timing chain because it was there and easy to get to, these truck oil pumps run off the front of the crankshaft, I had the O-ring get old where the pickup tube meets the pump , the old pump was fine but it’s a big job to do so while I was in there I swapped everything (new harmonic balancer too) so I didn’t have to do it again.
Headers / Cat-back exhaust
Trailer
Custom trailer on a M116A3 Military frame
Square drop design
35-inch tires – on H2 rims
RV rubber roof
Queen size bed
LED Smart TV
30 Gallon water tank
2 LION energy 105 AH lithium batteries
Renogy 3000W 12V Pure sine inverter
200watts solar on the roof / 100Watts in front
Renogy solar converter and CTEK (added later to charge from the truck)
Custom Pelican case storage box
Outside instant water shower / with custom slide-out curtain
Rear Kitchen with Coleman stove
Butcher block side table (magnets hold it to the fender and 1 leg to the ground)
270 Awning
The exterior covered with durable Polyurethane Protective coating with partial wrap
front is covered with a diamond plate patterned thin sheet metal
Plumbed for Up down air system
LED rear lights
External Diesel heater
These items are my pride and work but we have acquired an LMTV and we are building it to see the world so it pains me but to do that these must go
gp01
