2003 Land Rover Range Rover HSE
jrt198
2003 Land Rover Range Rover HSE $15000
Runs and Drives Great!
Located in Berlin, MD
191xxx miles
Upfitted with:
OEM Land Rover roof rack
FuelPax 4.5 gallon cannister with locking mounts mounted to the roof rack
Renogy 100W solar panel mounted to the roof rack
Ctek Solar charge controller
MAXSA Escaper Buddy traction mats mounted to the roof rack
Optilux by Hella 4 led cube lights mounted to the roof rack as rear lighting
50 inch curved LED light bar on the front of the roof rack rated at 28500 lumens
T-Max Dual Battery system with the controller in the headliner
Dual Optima AGM Batteries (Yellow top up front, Blue top in the rear)
ARB 50 Quart Fridge Freezer on ARB slider custom mounted and hardwired to rear battery
ARB remote fridge monitor
ARB dual onboard air compressor with air fitting mounted next to fridge
Energizer 2000W power inverter
Audiovox Mediabridge with USB and bluetooth for phone calls and music
Upgraded the factory 6 inch woofers to Pyle Carbon Fiber woofers in factory box
Midland Handheld CB with magnetic antenna
Angry Beaver Shovel mounted to roof rack
HiLift jack mounted to roof rack
Lamin-X headlight and corner light protection
Johnson Rods 2" lift
20" Land Rover wheels with BFGoodrich T/A KO2's (With full size spare)
Land Rover Factory Trailer Hitch
Custom TAG front bumper
Smittybilt X20 10000lb winch with synthetic line
Factor 55 Flatlink
Cascadia 4x4 flip up winch license plate mount
Hella Micro DE projector fog lights with 3000k DDM Tuning HID's
DDM Tuning Ultra HID 6500k low beams
Osram Nightbreaker high beams
Upgraded to Brembo 4 piston Calipers up front
Hawk ceramic brake pads all around
Atlantic/British coated stainless braided brake lines
Magnaflow cat back exhaust
Upgraded rear tail lights to supercharged tail lights
Upgraded corner lamps to euro version
Element fire extinguisher mounted next to fridge
All interior lights upgraded to LED
OEM Land Rover rubber mats front and rear
Britpart GAP IIDControl bluetooth OBD2 tool with bluetooth
REPLACED
Engine at 181000 miles with a 61000 motor and put all new gaskets and hoses on motor, and replaced timing chain and tensioners
Trans 15000 miles ago with a brand new trans
Custom front driveshaft with serviceable ujoint
Front Air Struts with Arnott's
Radiator
Hoses
Motor mounts
Thermostat
Coolant tank and sensor
Britpart air filter
Spark Plugs
BavAuto performance coilpacks
Engine has had full synthetic LiquiMoly oil and OEM oil Filters since replaced
I have Changed the oil every 5000 miles
ALL fluids in everything were replaced last year at around 185k
This vehicle is in excellent condition, runs and drives great. Everything works as it should. It will come with all the Blueridge Overland Gear pictured. This Vehicle has been a labor of love for me since 2008, but now I have too many vehicles, and this one got bumped out of the garage, so its time for it to go. Just had a full paint correction, and ceramic coating done to it in January professionally. Vehicle has an immobilizer, and a push button start. Headliner was replaced a few years ago with black alcantera. Will come with 2 keys.
Alpo
Wow, what a build! Where do you carry the spare? Where do you find a custom TAG front bumper?
jrt198
Thanks! Well, I used to throw the spare on the roof rack on trips. But haven’t really taken it off-road in a while now. TAG went out of business 3 or 4 years ago, so this is the second one they made that I know of.
Alpo
Thanks. Did you find the 275/55-20 BFG tires to have enough sidewall? I think they are also offered in a 60 series. Love the Dogfish bottle opener. I guess you still have the rig? I'm about to embark on a mild build for my 07 which I've had for almost 12 years.
jrt198
I’ve never had a problem with the 55’s. They have worked well on trails, crawling rocks, and on the beach. Yes I still have it. I was dailying it up until last week when I got a 3rd vehicle. Haven’t really been pushing it to sell, as I only have it on here and haven’t updated it since last year.
Houie
