miolnir
2003 Mercedes G500
Black on Black with wood grain trim. 155,902 Miles as of 2/9/14. Licensed and passed smog check in California. Tags good until April 22 2014. The first and last photo show stock springs/ride height and wheels in black. The last one is the G10 and Falken tire option on the optional list.
Off-Road Features
Maintenance:
$29,500
Optional Items:
I will do other modifications / accessories if desired for an agreed upon cost.
- 5 door / Long Wheel Base
- V8 5.0 Liter fuel injected dual spark plug 24 valve, aluminum block and heads
- Speed automatic transmission
- Transfer case with center lock
- Factory Locking Differentials
- Alloy Wheels painted metallic gray
- Nitto All Terrain Tires 275/70-18 (approximately 60%+ tread left)
- Anti-Lock Brakes, 4 wheel disc.
- Cruise Control
- Fold-Flat Rear Seats
- Heated Leather Seats - front and rear
- Power Seats
- Infrared Keyless Entry
- Multi-zone Climate Control
- Navigation
- 6 speaker multi disc sounds system
- Power Locks
- Power Mirrors
- Power Windows
- Rear Window Defroster
- Factory Security System
- Steering Wheel Control
- Sunroof
- Tilt and Telescoping Steering Wheel
- Heated Steering Wheel
- Tinted Glass
- Traction Control
- Headlight Washers
- Trailer Hitch with 7 pin connector
- Fog Lights
- High output blue tint Halogen PIAA light bulbs
Off-Road Features
- Front Runner Outfitters Aluminum 2 meter Roof Rack, with table slide, stainless tie-down rings and Expedition Corners ($1410)
- Front Runner interior ceiling storage net, aluminum and carbon graphite ($380)
- VTS Roof Access Ladder ($525)
- VTS Aluminum Transfer Case Skid Plate (495)
- VTS Spare Tire Cover ($740) - painted to match
- VTS Exhaust Resonator by-pass ($600)
- Mercedes Tow Pin winch Bumper ($1895) - painted to match
- VTS front license plate bracket (when winch not in use) ($125)
- VTS Winch Carrier ($480)
- Viking Offroad 9,000 Lb winch with Viking Synthetic Winchline and Safety Thimble ($1,250)
- Viking Aluminum Hawse Fairlead ($70)
- Viking Offroad Nickel Plated Recovery Hitch and shackle ($155)
- OME Heavy Duty +2" Springs and Nitrocharger Shocks ($1030)
- Total Off-Road Parts installed: $9,155
Maintenance:
- All fluids replaced 151,665 in axles, transfer case and engine. Engine due for oil change in approx. 1000 miles, recommend transmission oil change service
- New discs and rotors (rotors and pads cryogenically treated for longevity)
- Full brake system and locker systems fluid replacement with Mercedes DOT5+
- Recommend replacing AC pump due to slow leak
- Current service record spread sheet will be available with truck
$29,500
Optional Items:
- Used OE Stainless Running Boards $600 installed or new VTS Aluminum Running Boards $1,240 installed
- VTS Rock Sliders installed $780
- VTS Off-Road Rear Steel Bumper $2300 installed, paint to match $700
- G10 Forged Aluminum Beadlock Wheels (polished aluminum), on Falken AT 305/65-17 (approximately 50 miles on the set) $2600, new $5,650
