2003 Mitsubishi Montero flashing cdl
cyrusreyes
it Worked!
Thank you Viper and Clmrt! I order the part from Japan Through Amayama I was able to to get it for $110 including shipping. It worked like a charm! Part MR430381 is the part number.
I have the 5 transfer case sensors. When My mechanic was about to install the sensors we found out that you cannot tilt/ swivel the transfer case. the space was very limited. The transfer case has to be taken out before you can install those 5 sensors.
A lot of work involved so we did not end up installing the transfer case sensors.
So After installing the Solenoid Valve I test drove it for straight 50 Miles about 40 minutes of driving cruising 60 MPH, No More CDL Flashing light!
Part MR430381 fixed the issue! - 2003 Mitsubishi Montero-Pajero-Shogun XLS
However, I have one issue around 2000 to 2300 RPM I am experiencing vibration. not sure where its coming from. any ideas?
iStan814
