2003 Overland Built Nissan Xterra SE Supercharged
MountainHopper
***FOR SALE***
Asking $8500 OBO
Contact Justin: 954.529.5300
Colorado Based
Full Build Sheet/Photos here:
https://bit.ly/2SkKVJ3
  • Extensive work, maintenance and upgrades went in this Xterra transforming from stock into an awesome and very reliable overland/off roading vehicle
  • All service history available
  • Looking to pair with a great new owner!
  • ~ 143k Miles (Average of 10k miles a year)
Xterra Maintenance/Repairs/Upgrades 2017-2018
  • Timing Belt, AC Belt, Power Steering Belt (All Engine Belts)
  • Fuel Filter
  • Spectre Cold Air Intake Filter
  • Bilstein 5100 Shocks x4 & Alcan Complete Leaf Packs Upgrade/Replacement in Rear Producing 2” Lift and 350 lbs added support
  • Shrockworks Black Powder Coat Rock Sliders, Dimpled Tread Plates
  • New Distributor Cap, Rotor & Spark Plug Cables
  • Replaced Valve Cover Gaskets
  • Relocated & Replaced Knock Sensor
  • Fuel Pressure Regulator Replaced
  • New Seals on Upper Intake Gaskets for Supercharger
  • Replaced PCV Hose, SC By-Pass Valve Vacuum Hose, SC Control Solenoid VAC line and Intake Air Temp Sensor Mount
  • Transmission/Transfer Case, Trans Cooler Hose Front & Rear Diff Fluids
  • Hankook Dynapro MT RT03 265x70r17 x5
  • Powerstop High Performance Brakes/Pads/Rotors in Front & new shoes in Rear drum w/ Brake Fluid Flush Service
  • Power Steering Fluid Exchange
  • Coolant Flush Service
  • Rear Main Seal & Oil Pan Gasket Replacement
  • Swayaway Upgraded Front Torsion Bars for 20% Additional weight Support for Bullbar, Winch and 2 in Lift
  • Curt Full Sized Roof Rack with Hi-Lift Jack Mount
  • ARB Bull Bar w/ Warn 10k Winch w/ Steel Cable
  • Nilight: 2 LED Light Bars - 1 42in 240W Curved Spot Flood Combo, 1 25in 162W Flood Spot Combo, 2 18W Flood LED in rear bumper w/ Illuminated Rocker Switch
  • Mictuning HD+ 12 Gauge 600W LED Wiring Harness w/ 40 Amp Relay
  • 8 Mictuning RGB Rock Crawler Lights via Bluetooth Control
  • Bartact Paracord Grab Handles
  • HEPS Design Rear Window Molle Inserts
  • TAC TLG Tail Light Cover Guards
  • Kenwood Receiver and Mono Amp for Sub Hookup
  • Esky 180 Degree Full Color Backup Camera
  • 3/16” Vinyl Coated Limb Risers, 920 lb Breaking Strength
  • 2 in Shackle Hitch Receiver
  • Hitch Receiver Tire Mount
  • Cobra 29 LX 40 Channel CB Radio w/ 5ft FireStik Tunable Tip
BONUSES!
  • ALSO - Comes with Full set of 265/65R-17 Kumho All Terrian Road Venture AT51 SL Tires (Less than 1k) and 2 other Spares
  • Custom built 2 drawer utility system for rear deck w/ slide out wood tray for gas stove
Pictures
*NOT INCLUDED: Fox Wing Awning, Rotopax, Hi-Lift Jack, Storage Bins, Accessory Bags on Molle Panels, Dometic Fridge, Rigid Solar Box (or anything not listed in above bullet points)
***Also Important to note: There is some minor cosmetic damage such as “desert pinstripes” and damage right above rear passenger fender. Interior/upholstery/engine bay in very good condition!
4xCoffee
