noJeepshere
Good looking truck!
cent frum a smaert fone
Nice work. If you are still running the 10 bolt rear axle I would suggest a semi float 14 bolt as an upgrade.
9.5 inch ring gear, no carrier breaks, bigger tubes and bigger brakes. For your body style they came in 1500 tow max packages. Earlier ones had 13 inch drum brakes. Same axle is used in light duty 3/4 ton trucks, but it can be found in six lug applications starting with the 88 trucks.
I like the coil setup for flexibility. I was looking at Nissan Patrols, Mitsubishi Monteros and Toyota 80 series Land Cruisers. They use a 2 bolt saddle mount on the axle and a panhard rod. No need for the 3rd or 4th link. The frame mount of the radius arms is similar to a twin I beam Ford. It allows some pretty serious flex as well with a slightly simpler setup.
It will be fun to see your pictures of the full size trucks on the trip.
It was just a suggestion for the future.
I've blown up every 10 bolt with a G80 locker I've ever owned and I am not hard on my rigs. The gov lock has a nasty habit of locking in when it should not and catastrophically destroying the rear axle. Some were salvageable enough that I just made a tight LSD out of them. The rest I replaced with a 14 bolt for a one and done repair. Plus I like the bigger brakes of the 14 bolt.
My plans are a Ford HP Dana 44 with 6 lug hubs or maybe a unit bearing set of knuckles like you did.
I may have missed it in your thread, did you install the later model dual caliper piston and if so what caliper brackets did you use?
Edit: saw post #73 about the Dodge front end with dual piston calipers, so I guess you are now running single piston calipers with GMT 400 rotors.
As I recall, IF you ever wanted to there are 2 applications for 8 lug 3 bolt unit bearings.
Nothing wrong with a 44 front on a full size rig, Chevy, Dodge, Ford and International built millions of 3/4 trucks with them. I pmed Chris on Pirate when he was doing the Suburban and suggested the fix, but for him the supply up in his neck of the woods was lacking for the solution below.
Late model Dodge unit bearing knuckles may not swap, but early ones will and do have a 3 bolt 8 lug unit bearing.
Not impossible to find, but not as easy as a later 94 and up ones. They are off the early passenger drop front axles, before they went back to free wheeling front hubs and 5 on 5.5 bolt pattern on the 1/2 tons. Those early unit bearings were 5 on 4.5 bolt pattern for 1/2 tons and 8 on 6.5 for the 3/4 tons. They both used the same axles and knuckles, the only difference was the unit bearings, and brakes.
Question is, is it worth swapping unit bearings for a full floating axle and hub on a HP drivers drop Ford Dana 44? For most, no not really.
I saw cyclic post a photo of a caliper bracket and a dual piston caliper, what application was that in?
