Hello
My beloved Sportrider is going up for sale as I will be moving on from Thailand in a few months time. It's a 2003 Toyota Sportrider 3.0 D4D. It's basically a Toyota Hilux Surf or 4 Runner that is assembled in Thailand. I'm looking for THB 699,000 but could move a little. Note it's best to contact me by my mobile number at the bottom of the post, I don't often get time to check this website as I am travelling a fair bit.
Spec
• 3.0L D4D Diesel engine
• 4 speed automatic transmission
• Independent Front Suspension
• Live rear axle with limited slip diff
The mods I've put in are:
• Ironman Roof-Top-Tent
• 50mm lift Heavy duty front Sway-A-Way torsion bars
• 50mm lift Heavy duty rear ARB Leaf springs (constant 250Kg) with Ironman greaseable shackles
• Australian DBA slotted and ventilated brake discs at the front
• Ferrodo performance brake pads and stop flexi stainless steel brake hoses
• Custom stainless steel double drawer system (sitting on a homemade plywood floor)
• ARB 47L fridge/freezer with a custom stainless steel fridge slide
• Custom cargo barrier
• Projecta 150A dual battery system (second battery is the same as cranking battery not a leisure battery - I wanted the cold cranking amps)
• National Luna dual battery monitor with alarm
• Custom stainless 80L water tank with inspection hatch, gravity drain and internal baffles
• Internal LED lighting
• Light Force Striker 170 Spots at the front and a wide beam fog lamp at the back
• Reverse camera, inverter, various 12V outlets and 220V sockets
• Front and rear diff breathers have been extended up to the bulkhead and fuel filler cap respectively
• 5 New 31" Bridgestone Dueler ATs (original tyres are 30")
• Ceiling mounted monitor for DVD player to keep the kids happy
• Electronic safe for passports etc.
If you are interested please contact me on the forum or call +66 818 312 376. Thanks.
Spec
