2004.5 Dodge Ram 2500
2004.5 Dodge Ram 2500 SLT 4x4 with 5.9 Cummins.
174,100 miles
The exterior and interior are like new for the most part. There’s a couple rock chips and a scratch on the bumper from off road expeditions. No dings or rust. The interior looks new.
Plateau Diesel in Washington did a 3 hour prepurchase inspection in 2019. All the systems were checked and good. Pre def diesel that puts out great power and runs and looks perfect. Clean title all paid off.
Over $35,000 dollars in new parts and upgrades over the last 5 years. Some of the bigger additions include:
Transmission
Firepunk competition stage 1 48RE (rated for up to 800 hp)
33,000 miles on it with a full service and flush recently
FUEL SYSTEM
BBi 1.5 injectors (rated for up to 850 hp)
Bosch fuel rail
6.7 Bosch feed tubes
Cat/baldwin in line filter kit
Banks ram
AIR/TURBO
Fleece cheetah turbo (rated for up to 650 hp)
S&B intake with new air filter
Ice box oversized radiator and intercooler
New factory radiator hoses
Newer water pump
Newer pulleys
New belt
New batteries
Newer battery cables
Newer grid heater relays
Newer alternator
BD manifold
Arp 625 studs
Amsoil secondary bypass oil filtration system
Etc.
INTERIOR
Smarty touch controller for engine management
Kenwood touch stereo with back up camera (backup camera has not been working as of late)
JL auto components with receipts total $3,500 for system
3 pillar gauges for EGT and fuel pressure
Trailer brake controller
Aftermarket leather/suede interior
SUSPENSION
Thuren suspension and track bar
King pintop 2.5 shocks & bump stops
Carli heavy duty rear leafs & thuren front coil springs
Thuren front arms
King steering stabilizer
Thuren track bar & sway bar
Rehead heavy duty steering box
BD Diesel steering box brace and new steering joints
All bushings replaced
WHEELS
Newer brake pads and aftermarket rotors
Method 18 wheels with two full size spares
BFG ko2 35x12.5x18 (35%)
EXTERIOR
Fender flares & mud flaps
$3,000 dollar snug top canopy with int. light
Spray in bedliner
Custom welded rock sliders/steps
ARB front bumper
Hella 4000 100w lights
Mule expeditions in Washington did the suspension install.
I bought this truck about 4 years ago as my kids were getting to big for the Jeep I had. The truck checked every box and looked and ran great.
The guy I got the truck from bought it on impulse and the previous owner (a doctor out of Portland, OR) was very meticulous and a perfectionist type. He also had more money than sense. He buys a new rig and completely tricks it out, then sells it and buys something else. He moved on from the Ram and started building a 4runner.
The last owner took the truck to Plateau Diesel in Enumclaw, WA in 2019. They specialize in older diesels and have a good reputation. He paid $500 dollars for their 3 hour prepurchase inspection. They went over the entire truck, and everything checked out except for some minor parts. (New alternator, batteries and two new grid heater relays. I have the paperwork with their report).
Performance Diesel Authority here in Helena has done most all the general maintenance on the truck since I’ve owned it. They have checked it over for me on occasion and installed the new radiator hoses and batteries along with the addition of an Amsoil bypass filter system. They also flushed the transmission and installed new fuel filters for the truck. I have used Amsoil synthetic for the engine and have a full fuel and oil set for the next service interval. I recently had a new steering shaft, ball joints and tie rod end put in the front to tighten everything up there.
I am not sure there is a part that has not been upgraded on the truck. All the parts are top notch. I have receipts for some of the parts.
Inside the bed there are some minor chips in the linex bed liner and the power adjuster on the passenger mirror doesn’t work. There is some clearcoat peeling on the driver’s fender. Other than that, everything works and looks as it should.
I am listing for $33,500 obo. I have other cars that I use for commuting and general travels so this truck sits in my carport. It mostly gets used for longer distance camping/expedition trips.
No loan and have title.
Any other questions, videos, pictures let me know.
sunnyaz
