2004 Dodge Ram 3500, CCLB Single wheel, 4x4, sorted
2000LJ
2004 Dodge Ram 3500
Early 04 truck without cat from factory
Crew cab long bed single wheel 4x4
213k on Od but nearly everything new or serviced recently
Will be professionally detailed with buff and polish prior to sale
Asking 30,500 or best offer
505eight50three079
I have owned the truck over 10 years and it has been my baby the whole time, it has driven from coast to coast and from the Great Lakes to Gulf. It runs outstanding, and has been through a number of versions of builds over the years. I have been toying with selling the truck to buy a newer truck, I’ll also be selling my 04 F450 service truck/camper hauler too. Trying to thin the heard out….
Clean title in hand, still driven weekly but has only done about 20k miles in the last 3 years. Many spare parts that will be included. I know I am missing items but here is the bulk of the information.
The basics….
5.9 Cummins Turbo diesel approx 600hp
● All oils Amsoil only, oil changed every 7-8k miles, batteries in 2024
● ARP Head studs, 60% over S&S injectors, amsoil bypass filter, MBRP 5" Exhaust, GDP Power-Flo Air Intake, GDP Air Boss Plenum, GDP Grid Delete, IceBox Intake with Amsoil 4091 Filter, ATS Pulse Flow Manifold coated in High Temp Silver Ceramic, BD Special 64.5/74/13 Turbo, T&C Diesel WILD Fuel Rail, T&C Diesel CPRV, Industrial Injection Dragon Fire 85% CP3, MM3 tuning with 4 tunes, 12v tune included, FASS fuel system and lines new 2023, OBS fan clutch conversion
○ Water pump, thermostat, coolant, alternator, AC compressor, idlers, tensioner replaced in 2021
○ PS pump replaced in 2023
● 48re automatic transmission built to 750hp, Built by Bledso Diesel in Lubbock Dec 2024, under warrantee still but has 8k miles approx, Mag-Hytech Double Deep Trans Pan, BD FleX-Plate, Billet Output Shaft, Billet Input Shaft, Goerend Valve Body Goerend Triple Disk Torque Converter , HD Band Anchor: "The Power Wedge", Billet Rear Band Servo w/ Pin, Sonnax Dodge 16% Oversize Intermediate Super Servo, Sonnax Billet Servo Cover and Billet Pin, Sonnax Front Servo Piston Cover, Billet 4.2 Apply Lever, Billet HD Strut, BD Diesel Noise Filter, New transmission cooler and lines
● Stock transfer case, cut and retubed front drive shaft for pushed front axle, one piece Dodge aluminum rear driveline, new u joints 2024.
● Front axle rebuilt in 2023, 4.56 gears, Detroit trutrac LSD, stock axles, dynatrac ball joints, Yukon free spin Hubs, EBC green stuff pads, EBC slotted and drilled rotors, Centramatic wheel balancers, knuckles modified for double shear steering, solid diff cover
● Rear axle rebuilt in 2023, 4.56 gears, Detroit locker, mag tech diff cover, EBC green stuff pads, EBC slotted and drilled rotors, Centramatic balancers,
● Steering is bomb proof steering with FK rod ends, knuckles all modified to be double shear, pitman arm also double shear, track bar mount relocated forward to clear axle, custom track bar with FK rod end, DOR steering box brace, Steering box and pump replaced in 2023
● Suspension, 3” Synergy front coil spring, 1” rear shackle, 2.0 fox remote res shocks, adjustable front CAs, overload air bags with on board compressor and in cab control, aftermarket rear sway bar can be included but not installed
● Titan 60 gallon aftermarket fuel tank with FASS fuel system, Fuel system draw straw to use the entire tank. Best way to hold extra fuel!!
● Wheels and tires, 37x12.5x17, 5 Raceline wheels , 4 new Maxxis Razr MT tires and one BFG spare.
● Mercenary offroad front bumper with light bar mount, 12k lb winch, block heater plug, jumper cable connector.
● Stock style rear bumper in black, Class 5, 2.5” hitch in rear with mounts, led reverse light, Truck Camper mounts under bed, B&W turn over ball (not installed but included)
● Bedlined rear bed, bed has mount holes around, it does have 2 weak spots due to rust underneath,
● Exterior, black paint that is fading and pealing in places due to the NM sun, silver rockers and fenders that are perfect, bug deflector, window shades, 15% tint, aftermarket grille, “PigPen” sticker above exhaust tip, LED headlights, LED tail lights, LED cab lights, 3rd gen mirrors
● Interior, 6 seats with belts, all have covers however no wear or tears under covers at all, add on cup holders up front, additional USB and 12v plugs throughout cab, AC blows cold, heater is well a dodge heater, LED interior lights, Apline F309 headunit, Kenwood speakers in all doors and dash, 2x12” subwoofers in box under rear seat, alpine amp, new trailer brake controller, air bag control/gauge, trans temp gauge, Fuel pressure gauge, MM3 gauge/tuner, 4x4 floor shifter, husky liner floor mats, stock carpet and Mats underneath in perfect shape, hidden under console storage, 400watt inverter under pass seat
● 2 sets of keys with remotes
2000LJ
Additional
2000LJ
Cont
sunnyaz
