2004 Ford E350 4x4 Quadvan with Colorado Campervan Pop Top $45k OBO
04QuadBear
🚐 FOR SALE: 2004 Ford E350 4x4 Quadvan with Colorado Campervan Pop Top 🚐
Are you ready to own the ultimate adventure machine? Look no further! This beast is not just a van; it's a rolling fortress of fun and excitement. Perfect for those who want to conquer the wilderness or just look really cool in the grocery store parking lot.
Specs & Features:
  • Engine: 6.0 Diesel with 100k miles. It's got more torque than a herd of wild buffalo!
  • Quadvan 4x4 Conversion: 2006 Dana 60 high pinion super duty front axle with coil springs, radius arms, NP217 transfer case, and a 44 Gallon Transfer flow extended range diesel tank. Basically, it's ready to climb Mount Everest.
  • Colorado Campervan Pop Top: Electric linear actuator pop top with hardwire and wireless remote. Includes artic double wall canvas insulation, Maxx Air ceiling fan, roof rack rails for cargo or solar, Themozite cabin insulation under custom Pine wood paneling, upper and lower dome light package, and 3” foam upholstered bedding on top bed. Added (2) CR Lawrence windows in cargo body. Sleep like a king, even if you're parked in a swamp.
  • Oil Changed Every 5k Miles: Because we care about your engine's feelings.
  • All New Front-End Parts (2022): Upper and lower ball joints, all steering components, new Bilstein 880 coil springs, and Bilstein 5100 front shocks. It's smoother than butter on a hot pancake.
  • 285/70-17 Goodyear Ultratrac Tires (2024): On 17” Method Wheels. These tires laugh in the face of potholes.
  • Fiamma F45 Awning (2024): Perfect for those impromptu tailgate parties.
  • Passenger Helm Seat Swivel: Because sometimes you just need to spin around and say, "Look at me, I'm the captain now!"
  • Toyota Sienna Recliner Seats: For those moments when you need to kick back and relax.
  • Skeletonized Removable Queen Bed: With a 3” memory foam mattress. Sleep like royalty, even if you're parked next to a dumpster.
  • Vantage Optics Full Headlight Replacement: With projector beams and HID high/low bulbs. Light up the night like it's daytime.
  • New Brakes on All 4 Corners (2021): Stop on a dime, or a nickel, or whatever coin you prefer.
  • 10000# Tow Receiver: No brake controller installed, but who needs brakes anyway?
  • New Dual AGM Batteries (Summer 2024): Because one battery is never enough.
  • Pioneer Double DIN Stereo: With Apple CarPlay and updated front door speakers. Jam out to your favorite tunes while conquering the wilderness.
  • Titled and Registered as Oregon Motorhome: Because why not?
Engine Updates (2021):
  • IPR Remote Oil Cooler Kit: Removes factory oil cooler and relocates to frame for easier service and reduces heat in engine bay.
  • IPR EGR Delete, IPR Update Turbo Drain Tube, IPR STC HPOP Update Fitting.
  • IPR Stage 1 Garrett Turbocharger: With VGT (bigger vanes for better EGT cooling).
  • Sinister Diesel Remote Coolant Filter.
  • SCT OBD Scanner and Tuner: With 4 stages for E350 Ambulance (stage 1 tune installed- 40HP economy and towing).
  • Scan Gauge OBDII Engine Monitor Installed.
Items Needing Addressed or Noted: (Currently working through this list, willing to negotiate price if items are not addressed before purchase.)
  • AC System: Currently not functioning correctly, there is a leak in the system somewhere. Needs dye tested to find leak and repair and recharge as needed.
  • Steering Drag Link and Steering Arm: Need installed to update all front-end parts to 2006 Ford F350 compatible parts (have parts but not installed).
  • Small Amount of Surface Rust: On roof front cabin corner that should be addressed.
  • Engine: Has very small oil leak somewhere on back end of motor, never amounts to enough to drip on the ground or change in oil level between 5k intervals.
  • Glow Plugs or Glow Plug Relay: Will probably need changed if used in colder climate. (I cycle the key twice when cold and it fires right up).
  • Small Parasitic Electrical Drain: On house electrical fuse panel. Could use a master switch installed when van is not in use or add house battery bank with isolator to resolve. (I keep a battery tender on the van when not in use).
  • Rear Shocks: Need changed (I can explain more if needed).
This van is not just a vehicle; it's a lifestyle. Own it, love it, and let it take you on the wildest adventures of your life. Contact me now before someone else snatches up this rolling fortress of fun! 🚐💨
$45,000 OBO
bradbarbz
