2004 Ford F-150HD 4x4 Tiger GT
Dtruj505
$12,500 Located in Ceder Crest, NM, Just East of Albuquerque. Feel free to contact me directly at dtruj505@gmail.com
This Provan Tiger GT box sits on a 2004 HD (7-lug axles) F-150. The truck has a 5.4 three valve and 185,000 miles. Manual Shift 4x4.
It is still registered as a truck in NM, with a clean title in my name.
This camper was initially built on a 1994 Astro Van Converted by Provan. The van suffered an engine fire; fortunately, the damage to the camper was minimal besides some warped aluminum and a melted rear bumper cap. The warpage on the rear driver's side can be seen in the photos; it is ugly but non-structural. The holes in the exterior, where the previous owner removed appliances, have been patched with aluminum and riveted into place. Additionally, a new extended height three-layer top from Colorado Camper vans and Aluminum lift panels have been installed. This is a project as the interior of the camper is striped and can be configured to your use and liking. The truck will need tires and an alignment before any long travel, as well as the front shocks and axles replaced (which come with the sale).
The truck and the interior are what can be expected for a 180k mile pickup: some paint coming off, some light dents, and scratches. The interior is in good order other than the seats needing to be recovered.
The following has been done to the truck in the last 2-3 months.
-New updated OEM cam phasers
-A new OEM timing chain set
-New OEM VCT solenoids
-Updated high-flow oil pump
-Uninstalled gaskets
Additional parts that will go with the truck and camper:
New front CV axles
New Front Rancho Struts (replacements for the current rancho 4" lift.)
Undermount propane tank (original to the camper)
Known issues:
Tiers are old and ride rough
Oil leak at the oil filter housing (replacement Gasket comes with truck)
Alignment needs to be done
The front driverside Strut a-arm connection broke and was welded by the previous owner (replacement comes with the truck for this reason)
gp01
