2004 International 4300 Dt466 $38,500
ArizonaDirt
International 4300 Crew Box DT466 and a Manuel Eaton Transmission with Detroit Rear Lockers. 131,365 miles. (I use the rig so the miles may not be exact). Strong, reliable camper that has taken me around the country. Title in hand.
Converted to RV / Overland Rig in 2015. Built for getting off the beaten path, way off the path. But yet no loss of the comforts you need for an extended adventure or a weekend away from it all.*
Engine in-frame rebuild done at the International Dealership, at 125,000 miles. Tires less then 5k miles, fresh oil change and serviced on a regular basis. Cons: Rear AC average at best, engine has small oil leak.
$38,500
Power Plant:
1 Honda Generator EU200i
1 Honda Generator EU2000i COMPANION
Go Power Pure Sine Wave Inverter 1500W
Go Power Smart Battery Charger*
Go Power Portable Solar 80 watt panel*
Go Power Inverter Remote
120 Volt shore power connection*
6 batteries 2 cranking, 2 house, and 2 floaters that can switch to either house or crank.
Camper Box:*
Two street legal seats with seatbelts
2" thick insulated body
R14 Insulation in camper ceiling and side walls
Shear plates and spring mounted body
Structural channel subframe
HVAC system, cooling 33,000 BTU, Heating 46,000 BTU (only when main engine is on)
2 Camper emergency exit windows
10 exterior lockable boxes
Adjustable Table Pedestal with custom table top*
Winter 62 QT Dual Zone Portable Fridge / Freezer MOD# FM-62DZ
Suburban Recreational Vehicle Drop-In Cooktop
2, 11 pound mounted propane bottles
40 gallons of potable water
Sink with pump faucet
Slate tile cook top
Wood floors with insulated and sound proof subfloor
Ceiling storage rack
LED lighting
120V outlets- 12V outlets - USB outlets
Chassie and Cab:
Access from front cab to rear camper*
100 gallon Diesel fuel capacity
Air brakes (ABS)
Air parking brake
Air suspension with rear air dump switch, lowers rear 6-8 inches
Air seats, adjustable
Power mirrors / Heated mirrors*
Cruise control
Trailer air break ready
Air tank for tool / tire pump
Rear air dump, lower 4-8 inches
Engine / Transmission:
DT466*
Eaton Transmission 6 speed + reverse (R-L-1-2-3-4-5)
Detroit Rear Locker
Exhaust brake
Tools / Spares / Miscellaneous:*
Mounted 5 gallon Metal Safety Can (gas)
Air Filter
Oil Filter
Air Tool Kit
Air hose
2 sets of keys
Porti-Poti
2 memory foam sleeping pads
Deshet
What is your interior height?
Is the transmission synchronized? (do you have to double clutch)
Thanks,
xander69
