2004 TJ Wrangler Rubicon - Driver's Side Rear Window (Soft top)
Rubicon
Hi all!
I've got a 2004 Wrangler Rubicon (TJ) & the zipper on my driver's side (left) rear window has broken - on the window, not the top itself. I've looked online & can't seem to find a replacement window for just the driver's side.
I've found several sites where they will sell all three windows, but since I only need the one, that seems to be a waste of $$$$…..
I called the dealership & they want $289 for the window! I can get a whole new top for that much $$$$..
I'm also thinking of taking the window to either an upholsterer or a sail maker (I'm in So Cal not too far from the ocean) to see if they can sew in a new zipper….
Has anyone had any experience with this? If so, I'd appreciate any help/guidance you could give!
Thanks!
RUBE
jscusmcvet
Any auto upholsterer should be able to fix that zipper for you. Should be significantly less that the replacement.
