2005 5.9 Cummins Ram 3500 with King shocks $25.5k Minneapolis, MN
DillyFPV
****I previously had this truck listed with the camper as a package but have decided to sell separately, THE POP UP CAMPER IS NOT INCLUDED IN THIS SALE, TRUCK ONLY!!!!**** I have not yet removed the camper from the truck, but when I do, I can get some new photos sans camper. Also note that I do have the tailgate. Thanks!******
Hello everyone, up for grabs is my 2005 Dodge Ram 3500 Laramie with 194k miles. This is probably one of the cleanest and nicely equipped 5.9 cummins trucks you are ever going to find. No joke, I will regret selling this truck. Its the right year, trim, and color, with all the right (very expensive!) mods. It's rust free, it's only seen salt one year but I coated the entire frame and suspension with cosmoline before hand. It's never really seen hard work or towing, its mostly just been driven on the highway across the country over and over by the previous owners. Its been immaculately maintained and upgraded. The leather interior looks almost new and the paint and body is in great shape. Its truly an awesome truck, and I have a stack of maintenance records and receipts for it the size of a phone book. A few things that were taken care of somewhat recently are: New injectors at 178k ($3500), drilled and slotted rotors, exhaust manifold, rear axle rebuild, transmission flush, filter and new 2nd gear band. There are a few little things that will need attention at some point such as a couple tie rod ends with leaky boots and a very small oil leak from the pan because of the thinner winter oil in it at the moment, but nothing beyond normal maintenance.
The following modifications were professionally installed by the previous owner around 150k miles.
-Thuren 2.5 custom King Shocks front rear, 2.75 tune, Thuren front springs, Thuren control arms, Thuren Rear long travel leaf springs and shackles. This supension setup is amazing. It make big bumps feel like they are not even there. You can literally drive over a curb or median at like 30mph and it just floats over it, it's hilarious.
-BD Track bar, sway bar end-links, and steering box brace.
-Synergy Steering tie rod kit with fox steering dampener.
-Dynatrac rebuildable ball joints.
-Factory Torsen LSD in rear axle.
-Pro Comp 17X9 rims with 35x12.5r17 load range D Toyo Open Country R/T tires. Full sized spare mounted under the bed included but was not installed when I took the pictures.
-Air Lift Ultimate 5000 air bags for load and camper leveling.
-AFE Cold air intake. As you can probably hear in the video, its a little loud. That not the fault of the intake, someone has removed the turbo silencer ring to make it sound like that, it can easily be replaced if you want it to be a little quieter.
-5” Magnaflow Turbo back exhaust with 5” Magnaflow high flow Cat. It’s a really nice sounding and reletively quiet exhaust tone that doesn’t drone on the highway.
-150 GPM FASS Fuel filter kit.
-Upgrade pressure solenoid and transducer in transmission. Deep ATS transmission Pan. Trans rebuild at 70k. I replaced the 2nd gear band and did a full trans service done about 2k miles ago.
-MagHytec rear diff cover.
-Upgrade 8.3 Mopar steering box, hydro boost, and power steering pump. The steering is extreamly tight and direct, it does not feel like a fullsize straight axle truck at all.
-Custom fabricated steel front and rear bumpers. These are one offs built for this truck by a very good fabricator. They are super beefy, they look awesome, and the coating has held up really well.
-Line X bed liner, bed rails, fender and rocker panels, and grill. Professionally sprayed, you can see in the photos how thick it is.
-New batteries this winter.
-This
was over 20k in mods and recent maintenance on an already very nice truck. You could not build this from a clean stock truck for nearly this cheap.
Give me a call or shoot me a message if you have any questions. Thanks for looking and have a great day.
Dylan 612 414 2723
Here is a link to a video test drive and walk around:
Here is a link to about 200 more photos:
