2005 Chinook Concourse XL 2100, WeldTec lifted, For Sale $58,000, Toccoa, GA
jfbutton
FOR COMPLETE PHOTOS AND YOUTUBE VIDEO OF THIS VEHICLE:
https://links.mkt3797.com/ctt?ms=Mz...Dc2NjA3OTcS1&b=0&j=Mjk2MTEwOTU0OQS2&mt=1&rt=0
This 2005 Chinook Concourse XL 2100 is road tested and ready for your next adventure. We have lovingly restored and enhanced this classic model to provide unique comfort, convenience, and off-grid capabilities well beyond the base vehicle. With 19 gallons of onboard propane capacity, 300 watts of solar, a 4KW Onan generator and 440 AH of Lifeline AGM battery storage, we have operated off-grid from coast to coast in the USA and Canada, including Alaska. With a 5-inch lift Baja suspension upgrade from WeldTec and oversized BFG K02 tires, this RWDChinook handles well off the pavement as well as on. The interior has been renovated to include Ultraleather upholstery and luxury vinyl flooring throughout. Updated television and CD/DVD surround sound system operate wherever you are thanks to the Magnum 1000-watt pure-sine inverter. Weak cell signals in remote areas are enhanced by the installed WeBoost mobile signal booster. A more complete listing of standard features and custom enhancements follows. Comprehensive documentation for all components/systems has been maintained and is organized in binders for easy reference.
Chassis Upgrades
  • Alcoa Dura-Bright 16” aluminum wheels
  • Professional installation by WeldTec of Baja suspension lift kit including: 6” lift coils, upgrade of I-beam and sway bar from 2004 Ford equipment to ’08-’14 Ford equipment, installed front and rear Fox shock absorbers and Fox steering stabilizer, custom rear leaf springs (As documented in the video made by WeldTec featuring our Chinook)
  • BF Goodrich All Terrain T/A K02 E-rated tires LT235/85R-16
  • WeldTec off-road black powder-coated bumper with skid plate and driving light mounts
  • Vantage Optics (HID) headlights and Lightforce Venom off-road LED driving lights
  • Four-wheel disc brakes upgraded with PowerStop Z36 Truck and Tow Heavy Duty rotors and calipers and new braided lines
  • Boss AM/FM stereo touch-screen receiver (supports Apple Carplay and Android Auto)
  • Wireless rear backup camera integrated with Boss receiver screen.
  • Trik-L-Start chassis battery trickle charger wired to solar power
  • ExoShield windshield protection film
  • 3.5-ton military Hummer H1 scissor jack w/Agile Offroad axle and frame adapter
Coach Upgrades
  • 440-amp hour Lifetime AGM batteries with master battery on-off switch
  • Magnum 1000-watt pure sine inverter/charger with battery monitor, D/C shunt and remote
  • Three 100-watt solar panels with Bogart Engineering Trimetric solar charge controller and remote
  • All RV interior/exterior lights equipped with LED bulbs and added additional LED gooseneck lights over sofa and dinette along with multiple USB charging outlets
  • Packasport Voyager 90XP roof-top cargo carrier (additional 16 cu ft of storage)
  • LevelMate Pro wireless vehicle leveling system (connects to smartphone via Bluetooth)
  • SurgeGuard 30 Amp RV surge protector with remote
  • King Jack Directional HDTV antenna
  • All fabric upholstery replaced with Ultra Leather, including driver and passenger seats
  • Sofa and dinette spring/foam cushions replaced with custom made 15 year high density foam and memory foam
  • Flexsteel jackknife sofa modified to provide a more stable platform for sitting/sleeping
  • Karndean luxury vinyl flooring with WaterHog mats at rear entry steps
  • Custom glass and stone backsplash at stove and sink kitchen areas
  • Custom-made blackout and privacy curtains
  • WeBoost RV Cell signal booster
  • Flat-screen Samsung TV and RCA surround sound AM/FM stereo receiver/CD/DVD player w/subwoofer.
Standard Chassis Features
  • Super duty E-350 chassis; 138" wheel base
  • 6.8 liter Triton V-10 fuel-injected engine with block heater
  • 4-speed automatic transmission with overdrive
  • 4-wheel, antilock disc brakes
  • Heavy-duty, 130 amp alternator
  • 37-gallon fuel tank
  • 4.10 limited-slip rear axle
  • Dual rear wheels
  • Molded fiberglass overhead console with switch cluster
  • Driver and passenger airbags
  • Tilt wheel with cruise control
  • Power steering, power windows and power door locks
  • 3-door keyless Python 460HP remote entry and security system
  • Digital rearview mirror w/outside temperature and compass
  • Remote/heated deluxe side mirrors with clearance lights (replaced 2021)
  • 6-way power driver seat base
  • Reclining driver and passenger captain chairs W/lumbar support
  • Fiberglass running boards with flares
  • Trailer hitch, 5,000 lb towing capacity
Standard Coach Features
  • One piece molded fiberglass shell, fully reinforced
  • Double laminated fiberglass inner roof liner with foam insulation
  • Insulated solid floor laminated to body
  • Thermopane tinted windows with screens
  • Exterior service center with water, electric and cable hookups
  • Auxiliary exterior shower (Located in service center)
  • Swing-down spare tire carrier
  • Side and rear lockable exterior storage compartments
  • Kwikee power entry door step
  • Aluminum roof rack with ladder
  • Rear & side porch lights
  • 10' awning with crank (replaced with new Fiamma awning 2019)
  • 5-way systems monitoring panel
  • 13,500 BTU roof air with heat pump
  • 16,000 BTU propane furnace with auto-ignition
  • Power Fantastic Fan roof vent with thermostat and rain sensor
  • Exterior GFCI receptacle
  • 30-amp/25' service cord
  • Low-voltage coach disconnect with audible alarm
  • Onan 4.0 KW generator with remote
  • 6-gallon propane hot water heater with auto-ignition
  • 19-gallon LPG tank
  • 32-gallon fresh water tank
  • Heated holding tanks: Gray: 35 gallon / Black: 15 gallon
  • Lighted dump valves and sewer hose storage compartment
  • Black tank flush
  • Day/night fabric shades
  • Cherry hardwood valances with indirect lighting
  • 3-way (110/12V/LPG) double-door 6.0 cu/ft flush-mount refrigerator
  • 3-burner propane cooktop
  • Microwave oven
  • Recirculating power range hood with light and fan
  • Corian Counter tops with double-bowl Corian sink and covers
  • Pull-out faucet
  • Cherry hardwood cabinet and spice rack with paper towel holder
  • Front and side overhead storage with interior lighting
  • Rear wardrobe closet
  • Shower/wet-bath with molded Granicoat sink
  • Marine-style porcelain toilet with spray wand
  • Recessed covered toilet paper holder
  • Medicine cabinet and towel bar
  • Power roof vent with light in bathroom
  • Smoke detector/CO gas detector/LP gas detector(all replaced 7/21)
  • Fire extinguisher
  • Hidden safe
  • Entrance door with window, screen door and deadbolt lock
  • 68"X36" dinette, 72"X48" Sofa, 72"X84" combined (makes King Bed
FULL DISCLOSURE
Our motorhome is in excellent condition for a 20-year-old vehicle. However there are a few minor issues that we want to be up front about. In two places, the dual-pane glass is slightly clouded when viewed from inside the coach. This affects the large window on the driver’s side of the coach and the rear door. There are two blemishes on the fiberglass shell of the Chinook, one near the driver’s side taillight and another above the passenger door. Also, the 120V outlet inside the cabinet dedicated for the microwave is not functional. When we use the microwave, we simply plug it into the outlet located directly beneath the cabinet. Please see photos documenting these issues.
sunnyaz
