I’m putting my truck and camper up for sale. I would like to sell as a package but I would separate if the camper sells first.
Note: in the photo the airbags were not inflated to level the truck.
The truck is a 2005 Dodge Ram 2500 with an auto 5.9 Cummins. 260k miles and in over all good shape. The truck has been used and has dents and dings but no major damage. The clear coat is failing in some places. The interior is in good shape with no tears or dash cracks. Zero rust.
The following has been done in the last year
-fuel wheels
-nitto ridge grapplers (about 34in tall)
-steering box
-fan clutch
-radiator
-all fluids
-belt
-idler pulley
-track bar
-turbo couplers
-rebuilt trans with billet converter
-control arm bushings
-tie rod ends
-ball joints
-shocks w/ level kit
-airlift bags
-bully dog tuner
-I have sway bar end links and bushings ordered
The previous owner, who I use to work with, did either injectors or the injection pump I can’t remember and can’t get a hold of him to ask
The truck has no leaks and very little blow by. It does have a 5th wheel hitch but I have never used it and I know the previous owner didn’t either.
The camper is a lance squire lite 165s. I bought it from the original owner about a year ago. It is made for a short bed but the previous owner cut the rear storage boxes to fit his long bed. The camper is in great shape and until last year was stored inside. No leaks and everything works. I replaced the interior bulbs for leds, replaced the flooring, and converted the plug to a standard 7 pin. It has a brand new battery and has been winterized. I serviced the heater, water heater and refrigerator propane burners. I did repair a tie down that was starting to separate by boxing the wood with metal angle iron. I have driven thousands of miles with camper and had no issues. The tie downs are frame mounted torklifts. Has roof mounted ac and a propane furnace.
Asking $22k
Located in northwest Arkansas
-fuel wheels
-steering box
-fan clutch
-radiator
-all fluids
-belt
-idler pulley
-track bar
-turbo couplers
-tie rod ends
-ball joints
-airlift bags
-bully dog tuner
Asking $22k
