2005 Dodge Sprinter Partial Conversion with extended range tank
elysium
http://sfbay.craigslist.org/pen/cto/5602653870.html
2005 Dodge T1N Sprinter
Mileage 248k
• 3 custom captains chairs in rear portion of van
• Extended range fuel tank (about 48-50 gallons)...so 800-1000 mile range on one tank. This was about $3k to install.
• Green Diesel Engineering Ecotune for improved mpg ($700). Available power is increased from 156hp to 180hp. Torque is increased roughly 60 ft*lb along with a broader torque curve. Fuel economy is increased by 2-4mpg.
• Two spare tires (one underneath, one on rear door)
• Airtabs on the rear portion of the van.
• Thule TB60 Top Track Roof Mount (just the tracks, no crossbars)
• Spray-on closed cell foam insulation on sidewalls and roof interior
• CLD sound deadening tiles between insulation and sidewalls/roof
• "High Idle" switch
• Cruise control
The aluminum/black "stuff" over the rear wheel wells is sound damper material
Injectors look good; no black death; no check engine lights
It does have 248k on it, so set the appropriate expectations. There are some small rust spots in the paint (dime to quarter size). That said, these vans are known to have gone 500k or more, so potentially lots of life left.
