2005 Isuzu NPR with 17" Super Single rims and New BFGoodrich All Terrain T/A KO3 LT315 /70 R17 Tires
crispychris
This is a bare chassis 2005 Isuzu NPR that I started converting to an overlander. I purchased and had mounted brand new Super Single rims from ATW Australia and new BF Goodrich K03 tires. This is the 5.2L 4HK1 turbo diesel and 2005 is pre def, so no def to worry about. Took the original box off the back and had some engine work done (new head gasket, some other minor work.). Truck has approx 300K miles (speedo sensor is not working but I have a replacement part in hand), full compression on all cylinders after new head gasket. Also had two additional leaf springs added to the rear axle to handle the full time weight of a habitat box. Also added a stock Isuzu fuel tank (I had it professionally cleaned at an Isuzu service center, but haven't done the plumbing to hook it up yet.) Truck will have 66 gallons of fuel capacity with second tank.
This truck is located in Asheville, North Carolina. I'm asking $9K. I have some other spare parts and maintenance items that I will pass on with the truck. I am happy to answer any questions you may have.
If you want the habitat that I built for it (it is a stealth box truck camper) I will sell them together. See last photo. (1000 Watts of solar, 810 Amp Hours Battleborn GC3 lithium battery bank, Induction cooktop, full Victron long term boondocking/offgrid electrical system setup, 100 gallons fresh water inside box, lifting queen size bed, two Isotemp stainless marine grade refridgerators, interior garage holds two full size bikes, Mr Cool mini split air conditioner and heat pump, Separette composting toilet with holding tank for liquids, Eberspacher diesel hydronic heater, list goes on....
The camper is currently not mounted on the truck chassis but could easily be put back on if you want both. Price is $59K for both truck and camper combined. I can send lots of interior photos of the camper if you are interested.
Thank you,
Chris Saint
sunnyaz
