2005 LX470 fully built and maintained, no rust, mint
gxgn
2005 LX470, White paint, grey interior
VIN JTJHT00W253554285
183,500 miles
$29,500
No rust
Fully built but never taken off-road
Fully baselined
The built was done by the previous owner 2019-2023, all of these have been added in the last 30k miles:
  • Dissent high clearance front bumper with Warn VR 10S winch, synthetic rope, Factor 55 fairlead and Prolink
  • Dissent rear bumper with tire carrier and aluminum tray swingout
  • Slee sliders
  • Bumpers, sliders and wheels are custom powder-coated anthracite grey
  • 33” KO2s
  • Old Man Emu shocks
  • Rhino rack
  • Dual battery system with Red Arc controller and Solar panel
  • SPC upper control arms
  • Dobinsons dual drawer with fridge slide
  • 10.2” Android head unit
  • Replaced dashboard lights with LEDs
  • Cobra CB radio and antenna
  • Pro Comp front lights
  • Cali raised rack-mounted lights
  • Under-vehicle lights
  • Wolfbox rearview mirror with front and rear camera
  • Rebuild dashboard lights, replaced with LEDs
Extensive maintenance including:
~155K miles – timing belt and heater Ts
~182K miles:
  • Brake booster (@toyota dealer, still under warranty)
  • Steering rack, fluid and tie rods (@toyota dealer, still under warranty)
  • Radiator and cooling fluid(@toyota, still under warranty)
  • Changed oil (@toyota dealer)
  • Slee steel brake lines (@toyota dealer, I provided the parts)
  • OEM front and rear rotors and pads, pins, rubber boots for sliding pins and new hardware
  • Front wheel bearing kit, seals, rings, caps etc (Koyo kit from Cruiserteq)
  • Greased needle bearings using the Slee tool
  • Font and rear differential fluid
  • Transfer case fluid
  • PCV valve
  • Cleaned throttle body and MAF sensor
  • Lubricated the drive shaft and U joints
  • Replaced cabin with OEM air filter
  • Conditioned seats using Leatherique
I’m not interested in trades. I can pick you up at Eastern Iowa or Quad City airport if you need. Clean title in hand.
gxgn
Addl pics
gxgn
More
gxgn
last batch of pictures
sunnyaz
