2005 Montero Limited $5,500 .... Virginia
Big4g63T
234k miles.
Professionally installed :
LED off-road lighting & switches + hidden light bar.
LED step rail lights
Custom LED fog lights white/yellow
Tow package & wiring
Touch screen Kenwood
Recent Work Performed :
Timing Belt & Water Pump @ 229k
Crank sensor & tensioners @229k
Serpentine Belt & Pulleys @229k
Denso A/C Compressor @229k
Transmission fluid & Filter @190k/229k
Front/Rear/center Diff fluid@220k
New Front CV Axles @190k
Front& Rear brake calipers @195k
Power Steering Rack @230k
Inner/Outer tierod ends @230k
Poly control arm bushings @231k
Bilstein Front shocks @231k
Upper& Lower ball joints @231k
Sway bar bushings+links @231k
Computer Alignment @231k
Front Rotors+ Brake pads @232k
4x4 freewheel actuator @232k
4 New Kenda Klever RT tires@228k
