green73brc
@@@@@@@@@@@@@ SOLD @@@@@@@@@@@@@@
If you are looking for a turnkey overland Sequoia this is it. This vehicle was built for long drives to rugged and remote places. We have kept the vehicle well maintained as we used it to travel to remote western state locations. Within the last 20k miles all major preventative maintenance has been done and will not need anything for many many miles to come. It includes a modified suspension for heavier loads. A fridge to supply cold food with a dual battery system to keep everything powered. On board air, rear storage and kitchen included. All you need to bring is your camping gear. This vehicle has be used for week long and for month long adventures. It can hold enough food/water/gear that our family of 6 would only have to resupply every week.
Our family has recently decided to move to a larger hard sided camping option. So here is your chance to own something ready for the outdoors. It will fit in a standard 7 foot garage. We have set it up for 1/2 the rear seat removed for more space giving us 6 Total passenger seats. I have the other 1/2 of the rear seat if you want to put it back.
I have a sheet of all maintenance done.
If you dont know much about sequoias this is the preferred 1.5 Gen with Variable Valve Timing, bigger brakes, and solid rear axle.
The Awesome
1 Arb 63 quart fridge/freezer with slide out, stove and prep area.
2 Rear storage/orginzation.
3 Perfect Switch Mosfet style dual battery system with 2 total AGM batteries
4 Old Man Emu 3 inch coils front and rear and matching shocks
5 Camburg upper Control Arms
6 Yakima Load warrior with expansion added
7 Arbs largest awning
8 Belly Skid plate that also covers the Cat Converter (to aid in theft prevention)
9 1/4 inch rock sliders that will support the weight of the vehicle
10 Baja Designs 10 inch LED bar
11 Baja Designs S1 Work/Scene Area Lights
12 On Board Air with Vair Compressor
13 Rear Air Bags for Load adjustment
14 Pioneer Head unit with Backup Camera
15 Rear Monitor that connects to Pioneer head unit with DVD player Keep those kids happy on 14 hour car days
16 4.5 Gallon Rotopax Fuel Storage
17 Treds longer version traction aids (similar to maxtraxs) the have been only used in the sand in Colorado
18 The stock electrical system is untouched anything aftermarket runs off the second battery with aux fuse panel
19 Weather Tech floor liners
20 Largest stock size BFgoodrich KO2 All Terrains
21 Rigid Industries Interior LED (over the rear cooking area)
22 Key interior lights converted to RED for night time use
23 2 Goal Zero Portable Solar Panels
The Bad
Some Dents on the rear Tailgate area
Exterior Paint has some bruises/cuts
Rear Interior is probably a 6/10 with markings and things from kids and loading gear
I lost the Goal Zero Solar charger but you can make or buy a replacement for 50 bucks
The front driver strut isolator must have been centered poorly since it has slipped out.
The VSC system is sensitive and will sometimes go off on hard turns. Had the dealer investigate on 3/2/22 and everything is working fine paid 175 for a diagnostic. They stated that it is a sensitive system. I have the paperwork I can show.
Replaced/Maint within the last 10k Miles
New KO2 Tires
Transmission FLush at Dealer
New Front Strut Bodies
Front Diff Oil Change
New Starting AGM Battery
New Air Filter
New Rear Control Arms
New Rear Sway Bar
New Sway bar links (front and rear)
Replaced/Maint within the last 15-20k Miles
Power Steering Flush
Rear Diff Oil
Transfer Case Oil Replaced
Steering Bushing Replaced
Lower Ball Joints Replaced
Upper Ball Joints Replaced
SAIS Pump and Diverter REplaced
Front Brakes
Timing Belt/Water Pump/Pulleys Serpentine Tensioner
Upper and Lower Radiator Hoses
The Awesome
The Bad
New KO2 Tires
New Air Filter
New Rear Sway Bar
Rear Diff Oil
Front Brakes
