2006 Jeep Commander in Colorado
Less than 23,000 MILES!! In Colorado $22,000 OBO
Warranty good until 4/5/2013!!
http://www.flickr.com/photos/61358810@N05/5588593653/in/set-72157626427151948/
• TRANSFERABLE!! (Purchased from Jeep)
• Contract Number 34033913
• VIN Number 1J8HG58236C105729
• Description 7YR/50,000 MAXIMUM CARE $100
• Expires on 2013-04-05 or 50000 miles Start Date2006-04-06
• Deductible Per Repair $100.00
• Towing Coverage $100
• Roadside Assist 800-521-2779
• Rental Car Allowance $35.00 per day for a maximum of $175.00
Jeep Stock Features
• Leather Trimmed Bucket Seats
• Dk Slate Gray/Lt Graystone
• Monotone Paint
• Quadra-Drive 4WD System
• 5.7L Eng(EZB)/5Spd A/T 545RFE(DGQ)
• 160 Amp Alternator
• Brake Assist
• Electronic Stability Program
• Anti-Lock 4-Wheel Disc Brakes
• Low Back Bucket Seats
• Premium Door Trim Panel
• Manual Driver & Pass Lumbar Adjust
• Lt Graystone Seats
• 3rd Row Seat (Not installed)
• 2nd Row 40/20/40 Fold & Tumble Seat
• Child Seat Upper Tether Anchorages
• Supplemental Side Air Bags
• Child Seat Anchor System-LATCH Ready
• Advanced Multistage Front Air Bags**
• Center Rear 3-Point Seat Belt
• Cloth Covered Headliner
• Supp. Side Curtain All Rows Air Bags
• Cargo Compartment Carpet
• Cargo Tie Down Loops
• Front & Rear Floor Mats
• Cargo Trim Panel w/Storage Net
• Full Length Floor Console
• Overhead Console
• Rear Overhead Console
• All 5-Speed Automatic Transmissions
• 5-Spd Automatic 545RFE Transmission
• Lock-Up Torque Converter
• Quadra-Trac II Full-Time,Active 4WD
• 200MM Front Axle
• 3.73 Axle Ratio
• 213MM Rear Axle
• Elec LTD Slip Differential Rr Axle
• Elec LTD Slip Differential Frt Axle
• 5.7L Hemi Multi Displacement Engine
• Tinted Windshield Glass
• Front Door Tinted Glass
• Deep Tint Sunscreen Glass
• Flipper Liftgate Glass
• Rear Window Defroster
• Rear View Auto Dim Mirror
• Pwr Heat Memory Folding Auto Mirrors
• Power Sunroof w/CommandView (TM)
• Remote Keyless Entry
• Sentry Key Theft Deterrent System
• Air Cond ATC w/Dual Zone Control
• Rear Air Conditioning w/Heater
• Hood Insulation
• Dash Liner Insulation
• Deluxe Insulation Group
• Floor Tunnel Insulation
• Instrument Cluster w/Tach
• 140 MPH Primary Speedometer
• Rear Window Wiper/Washer
• Rain Sensitive Windshield Wipers
• Dual Note Electric Horns
• Auxiliary 12-Volt Rear Power Outlet
• Locking Glove Box
• 12V Auxiliary Power Outlet
• Power Accessory Delay
• Power Locks
• Pwr 8-Way Drvr Mem 4-Way Pass Seats
• Heated Front Seats
• Pwr Front Windows, 1-Touch,Up & Down
• STRIPE/BADGE/MOLDING/COLOR
• Stripe/Molding/Badge
• Illuminated Entry
• Vehicle Information Center
• Courtesy Lamps
• Glove Box Lamp
• Rear Courtesy/Reading Lamps
• Cargo Compartment Lamp
• Radio/Driver Seat/Mirrors Memory
• Sylvania Silver Bright Headlamps/fog lights
• Automatic Headlamps
• Smartbeam Headlamps
• Fog Lamps
• Security Alarm
• Enhanced Accident Response System
• Bright Grille
• Chrome Bodyside Molding
• Body Color Rear Fascia
• Belt Moldings
• Body Color Door Handles
• Bright License Plate Brow
• 5.7L Badge
• Trail Rated Badge
• Limited Badge
• Jeep Badge
• 4X4 Badge
• 20.5 Gallon Fuel Tank
• Power Steering Cooler
• Speed Control
• Hydraulic Engine Cooling
• Bright Silver Metallic Clear Coat
• Steering Wheel Mounted Audio Ctrls
• Power Rack and Pinion Steering
• Leather Wrapped Steering Wheel
• Tilt Steering Column
• ParkSense Rear Park Assist System
• Power Adjustable Pedals w/Memory
• Universal Garage Door Opener
• Tire Pressure Monitoring Display
• Protective Coating and Remover
• Rear Seat Video System
• Four Wheel Drive (4WD)/(4X4)
Stereo System
Professionally installed. Custom amplifier, subwoofer enclosure with remote controlled linier actuated cover using ¾” MDF carpeted to match with steel mesh routered and recessed allowing full use of cargo area while hiding all the equipment.
• Alpine IVA-W505/P1 Navigation/dvd with I-Pod adapter
• KTX-100EQ Imprint Sound Manager
• Stinger SP1700 battery
• Stinger wiring and distribution blocks. 0 gage throughout
• Audio Control LC8 (Installed but no longer in-use do to the factory deck upgrade)
• Kicker ZX 640x4 Mid/Tweet amplifier
• Kicker ZX 1500x1 subwoofer amplifier
• Auto Meter amplifier voltage and temperature gage installed for amplifier management.
• Reverse camera integrated into the license plate frame
• 4 Kicker Solo-Baric 8” L7’s
• 2 sets of Kicker SS 65.2 (6.5 inch sets in both doors, front tweeters are in the dash)
• 2 Aftermarket 7” front sun visor monitors discreetly installed no wiring visible.
• Factory rear 7” ceiling monitor with DVD player and 2 wireless headphones. This is all wired into the receiver for full functionality
• 160 square feet of hush mat sound deadening material installed. The vehicle is VERY sound proof.
Lift Kit
Lift kit professionally installed by Ultimate Truck using nothing but the best. Lift kit and tires were installed at 1200 miles. Tires are like new. Never off-roaded.
• 4” Superlift with remote SSR rear shocks
• Kumho 325/60R18 KL78 tires
• American Racing SKAR 616 wheels
• Superlift EGR module to calibrate tire diameter change
Front Bumper
• Custom made by GetLost 4x4
• Coated with Line-X and color matched (The stuff you spray your pickup box with. It’s a rubberized coating protecting the bumper from bumps and scratches)
• T-Max 9000lb winch (EW-9000) Used one time and garage kept and always covered with a neoprene cover when outside.
• KC Hi-Lites 120Chrome 130W long range slim models. (These are switch operated and also wired into the auto-brights)
Performance
• Jet Performance Stage 2 Power mod and thermostat new in the box.
• K&N Cold air intake
• Custom installed Turbo muffler with chrome slash tip. (Single not duals)
Extras
• Viper remote start
• Eagle Eye LED tail lights
• Sylvania silver bright high/low headlights and fog lights
It is still for sale...a few more miles on it now just took it to Chaco Canyon and Bandelier National Park...did great.
iStan814
