2006 Lexus GX470 $25,000
BlueRidgeBomber
I’m new to overlanding so I may be off base. Is this a 2” lift with a 1” body or a 3” lift? I’m not seeing a 3” on Dobinsons website.
andyman1
I have a 1.5-3” Dobinsons adjustable lift kit installed. It can still be lifted some more by adjusting the ride height, and has a 1” body mount spacer.
Cheers!
BlueRidgeBomber
Is the body lift and body mount modification necessary to prevent tire rub near full lock? Could a guy eliminate the body lift and use a 33” tire? As well, are the rear spring perches adjustable in ride height?
Interested in your truck but 35’s are a bit overkill for my needs. Just weighing options at this point.
andyman1
Yep, exactly. The GX used to be on 33s with no body lift and wheel spacers, definitely doable again. The rear spring perches are not, but the shocks are.
Clemtiger84
