2006 Toyota Tacoma TRD With Aluminum Flatbed
Located in Seattle
2006 Tacoma double cab trd off road (with electric rear locker)
Truck has 120k miles and is in good working order.
Truck has custom all aluminum flatbed on rear with an aux battery underneath.
BlueSea automatic aux battery isolator (will automatically connect batteries for charging when driving and then automatically disconnect when stopped) you can manually connect or disconnect the batteries via dash switch as well.
There is a flush mounted battery monitor near shifter to keep an eye on battery voltage.
lightforce aux lighting is not currently hooked up but everything is there to run them. (also installed under hood is BlueSea aux fuse block.
Truck has OME 2.5 heavy duty lift. (also will include brand new OME add a leafs which were not needed when originally set up)
BFG KO2s
Weather tech floor mats
Aftermarket touch screen stereo (with bluetooth)
Seat covers
ARB front bumper
Selling to pay off other vehicle just purchased.
Craigslist with more photos located here. https://seattle.craigslist.org/see/cto/d/toyota-tacoma-double-cab/6662131583.html
4xCoffee
