2006 Tundra Double Cab with FWC Eagle Camper- Santa Cruz, CA (Sold)
ctrippy
I am selling my Four Wheel Camper Eagle. I purchased the camper last fall from a friend who was the original owner and I did a custom buildout of the interior. No water damage, funky smells or structural issues. Before building it out I did a full maintenance reseal of all seams/seals and roof screws, two fresh coats of pain on lower frame inside and out. I also upgraded all of the insulation to Pro Select R-Matte rigid foam board. It has all the amenities for comfortable four season camping and is set up to be light, simple and functional. Bed can slide out to create a full queen size sleeping area. The camper is heated with an Planar/Autoterm Diesel Air Heater 2D-12 High Altitude Diesel Heater with the Advanced Digital Controller. The diesel heater results in comfortable camping down to negative temps! The diesel tank is mounted on the exterior rear side of the camper for easy filling and monitoring of fuel level. If installing on a mid-size truck(Tacoma, Ranger, Colorado etc.) the fuel tank will likely need to be relocated to the rear wall of the camper. Very easy to do. The camper is powered by a Goal Zero Yeti 1500X power system that can be charged a number of different ways and features great power. Bonus is you can simply unplug it from the camper and use it for other things while not using the camper! The galley is setup to be easily be able to cook inside or outside depending on weather. Kitchen "drawers" are replaced with Front Runner Flat Packs making it extremely easy move the kitchen outside! The galley also features a 110v outlet as well as a USB and quick charge USB-C charge port. Refrigeration is handled by a Dometic CFX3 35. Sink is provided water via a quick connect 7 gallon water jug. There is additional room to expand the number of jugs for longer times away from a water source if need be. Water drains to the exterior of the camper where it can drain into a grey water jug or to the ground. There is also space under the sink to have the ability to drain into an interior grey water jug if desired. All cabinetry is built with ½” birch and the inside of the camper is lined with ¼” sealed cedar tongue and groove from easy cleaning. LifeProof flooring installed up cabinetry for easy replacement if needed. The camper features custom made Strawfoot insulated window covers and a standard roof vent. Bench seating provides ample interior drop down storage and a sleeping platform for sleeping with the roof down. Included is 4 Reico Titan camper jacks with extension plates and two crank handles. I would also consider selling the truck, making it a turn-key package. Below is truck info.
2006 Toyota Tundra Double cab SR5 TRD with 126,xxx miles. I am the second owner. I purchased it from the original owner(fellow WTW forum member) with 85k miles. I have a folder with all documentation of maintenance/service. Timing belt and fuel pump already done. An Oregon truck since new and transferred to California when I bought it, so ZERO rust! At 100k miles, I refreshed the stock suspension with a full Old Man Emu setup and Toyo ATIII tires on OEM steel wheels. Truck also would come with a matching LEER camper shell with yakima roof tracks. Truck specs below:
-Old Man Emu 884 front springs, AAL in the rear and Old Man Emu Nitro Charger shocks on all four corners
-285/75R16 Toyo ATIII tires
-OEM black steel wheels
-Spidertrax wheel spacers
-Firestone Airbags
-Daystar airbag cradles
-Hellwig rear sway bar
-Line-x bedliner
-Leer camper shell with yakima roof tracks
-Weathertech floor liners front and rear
-Weathertech window deflectors
Photos: https://photos.app.g...sSighL6nEUmkfQ7
You did a fine job rebuilding that old Eagle. What year is it, I don't think you mentioned that. I like the simplicity. But no place for a cassette toilet? I have a 1999 Eagle mounted on a 2001 Tundra, so very similar. I wish mine looked like this one. This is a light and fairly simple set-up with no overhang beyond the truck bed rails, but the bottom line is that there is limited storage space in these Eagles for your personal stuff. I've tried everything to gain some storage, every nook and cranny. GLWS.
ARcolorado24
Love this setup, good work! This is a dream rig for me but I don’t have the space for the camper at this time. What’s your asking price from the truck and leer shell combo?
ctrippy
Thank you, it’s a 2007. I’m not a fan of cassette toilets, so did not account for one in the build, but one would likely fit where FWC normally puts them right inside the door to the right or to the left under the galley. For the stock FWC builds I have found there to be very little storage, but made an effort to focus on a balance of storage and space on this build and never found myself needing more storage. I like to use the backseat of the truck for bulky items you don’t need all the time inside the camper and always remember less is more when packing for a trip!
ctrippy
Thank you! It really is a tried and true combo. Took me 6 months to find a truck that fit my criteria. I’ve had quite a bit of interest in it as a combo. Not sure I want to get rid of the truck if the price isn’t right for the combo. I will reach out if I decide to just sell the truck.
clayinho
I have an 06 Tundra Double Cab that you could pair with the camper if you felt compelled to sell the red truck with shell to someone. I'm localish (SF inland east bay).
What's the stand up height inside the Eagle when it's popped up?
ARcolorado24
No worries totally understand, let me know if you decide to split up.
rübezahl
what's your asking price for the truck+camper combo? $35k is just for the camper or? Thanks for the clarification - awesome setup by the way. Love that you made an effort to keep things light weight and simple!
kdenning
Man this is a long shot but if you see this can you let me know if you needed a platform under the camper to get it to fit in a 2006 double cab Tundra bed??
We're shopping for a FWC And found a perfect Eagle for us but it's going in our 2006 Double Cab Tundra and it's a deal-breaker if I have to build a platform to elevate the camper to clear the bed rails...
Fingers crossed you see this and have the time/kindness to let me know! Text is fine if that's faster at (530) 523 3415.
You should message the user directly
sunnyaz
