Greenmonkey
2007 Adventure Trailer (AT) Horizon
$16,000
Rock Island WA. 98850
Contact@ Tyler.augustson83@gmail or PM
*Only used about a dozen times and it has always been stored inside.
*Factory options/features*
-285/70r17 BFG A/Ts on Toyota rims
-Eezi-awn RTT in perfect condition
- Kitchen with Partner Steel stove, cutting board integrated into kitchen "door"
- 19 gallon poly water tank
-Onboard 12v fridge
- Full Powder coated box and frame
-Tongue box with shore charger, group -31 AGM battery, shore power hookup, -multiple power plug ports throughout
-Jerry can holders (2) [lockable], with (2) jerry cans
- Awning with telescoping mounts
- Two 10lb "pancake" propane tanks /
mounts (both with current certification)
-Accessory 2" hitch on rear
*Manufacturer Specs*
Overall Length 124"
Overall Width 68"
Main Cargo Box 40"W x 30"H x 54"L
Side Box 14" W x 14"H x 54"L
Nose Box (31" W + 15"W) x 19" H x 16.5"L
Water Tank 19 Gallons
Propane Tank 11 lbs (x2)
Gas Cans 5 Gallons each
Base Trailer Weight 1100 lbs. (guessing
closer to 1500-1600lbs as equipped)
Payload 1600 Ibs.
Ground Clearance 24"
Box Material 14 Gauge Zinc Washed Steel
Chassis Material 2" x 3" × 1/8" steel tube
Bumper material 2"' × 5" x 3/16" steel tube
