2008 AWD Chevy Express Camper Van, Lakewood CO
ctles
We are selling our 2008 All-Wheel Drive Chevy Express camper van. We have had many great all-season adventures in it, but our lives are getting too busy to continue to take the adventures we used to take. This van was built with great attention to safety. The bed frame and fridge cabinet are custom made from steel both of which are bolted to the van body using rivnuts and grade 8 bolts (the same as used in cargo vans). The drawers are hung on locking drawer slides that lock in or out and are rated to 600 lbs. The entire interior has been spray foam insulated and is heated during the winter by a Webasto heater that runs off of the van fuel tank. The Webasto heater will keep this van toasty even in sub-zero temperatures and eliminates fire and asphyxiation risks that other heaters pose. The van is all wheel drive and has a locking rear differential (G80), which means this van is practically unstoppable. It handles exceptionally well in the snow and on rough terrain. It is extremely hard to come by these vans today, especially with less than 100k miles.
Asking $45,000
Van specs:
  • 5.3 Liter Gen 4 LS (LMF) engine
  • 301 Hp
  • Payload: 1,707 Lbs.
  • Towing capacity: 6,100 Lbs.
  • All wheel drive
  • G80 rear locking differential
  • Fuel tank: 31 gal
  • Front airbags for driver and passenger
  • 2 inch leveling kit with Pro Comp shocks installed by Boulder Offroad Vans
  • Baja Designs Squadron Sport driving lights (that can be turned on/off with high beams or remain on all the time)
  • Baja Designs SAE amber fog lights
  • Auxiliary backup lights
  • Two additional circuits wired and ready for additional lights/accessories if desired
  • Sony head unit and backup camera are installed to make backing up easy (head unit supports both Apple Car Play and Android Auto)
  • Three USB charging ports accessible from front seats
  • Passenger seat swivel
  • Van Registration is current and title is in hand
  • odometer: 98570
Build specs:
  • The entire van (ceiling and walls) is spray foam insulated with fire retardant and mold retardant foam
  • Floor of entire van is covered in rattle trap sound deadener and covered by heavy duty floor liner that will stand up to ski boots, bike shoes, climbing gear etc
  • All doors covered with rattle trap sound deadener and upholstered
  • Walls are upholstered with mold and mildew resistant marine grade carpeting
  • Ceiling is covered in sealed birch paneling with two touch on/off lights over the sleeping area
  • Bedframe and fridge are bolted to van body using rivnuts and grade 8 bolts to protect occupants in the event of an accident
  • Drawers are mounted on heavy duty drawer slides rated to 600 lbs with locking mechanisms that prevent drawers from opening during a hard stop and keep drawers open for easy access if van is parked on an incline
  • Side pantry opens with the assistance of a gas piston hinge that keeps lid open when in use and keeps lid closed when not in use
  • Beneath fridge storage stays closed with a marine grade cam lock
  • Fridge is a 1.8 cubic foot Truck Fridge with freezer compartment
  • Dedicated storage for two 7 gallon water jugs (14 gallons) designed to make filling water bottles, camelbaks, pots etc easy
  • Maxxair fan above sleeping area for ventilation
  • 100 watt Renogy solar panel installed with easy option to expand to additional panels if desired
  • 100 Amp hour AGM house battery charged from alternator (when van is running) and solar panel
  • Solenoid separating house battery from engine battery to prevent discharging van battery
  • One 400 watt inverter for 120 v plug
  • Electrical system components are Blue Sea Systems
  • Three 2.1 v usb ports
  • One 12 v cigarette style receptacle
  • Viair On-board compressor makes flats a thing of the past
Babbert
