2008 e150 tires, 235/85r16?
MrKen
Time to replace the tires. Currently have 225/75r16, standard stock size. Thinking of increasing the ground clearance a bit.
I would like to use the 235/85r16, 32"dia, will they work without issues?
I have read some have used a 265/75r16, 32"dia, wider (which I don't need), but I don't know if they had rubbing.
What is involved if I add a 2" lift? haven't researched this yet. Will the 235/85r16 fit then?
Thank, Ken
WVI
The E150 front springs may be a bit to soft for these. They should fit the rear fine.
