2008 Ford E-350 6.0 Diesel Camper Van
Gride7
I am thinking about selling my 2008 Ford Econline E-350 Van. It has 160,xxx miles on it. I have put A LOT of money, time and work into this van and am really torn about selling it but if the price is right it's time for the next project/adventure.
I am looking to get $90K for it. Could possibly be negotiable and open to trades. Below is all of the info on the build. Please let me know if you have any questions and feel free to email me directly at gride7@gmail.com
Engine
-6.0 Diesel
-Resurfaced cylinder heads
-New head gaskets
-ARP head studs
-EGR cooler removed
-New turbo Y pipe
-New turbo mid pipe
-Custom diamond eye full exhaust
-New injectors
-New glow plugs
-New wiring harness
-New alternator
-New water pump
-New vacuum pump
-New thermostat
-New belt
-New VGT turbo ring
-New belt tensioner
-Recharged AC
-New exhaust manifold gasket
-New upper head valve cover gasket
-New valve cover gasket
-New EGR valve gasket
-Updated dummy plugs
-New intake air temp sensor
-New K&N drop in filter
-New heater core hose from water pump
-Oil filter relocation kit
Drivetrain
-4x4 conversion by UjointOffroad
-6” lift with Fox 2.0 shocks all around
-Stage 2 Dana 60 front w/ RSC upgrade and 4.54 Detroit true trac LSD
-(RSC upgrade includes the following: New steering knuckles, spindles & hubs, serviceable wheel bearings, ABS tone ring & sensor mount, 35 spline stub shafts, F550 14.5" diameter brake rotors, calipers, crossover steering, and a high clearance tie rod assy.)
-Stage 3 Sterling 10.5 rear w/ ARB air locker and 4.54 (Stage 3 includes heavy duty full floating rear axle from the F350s with all brand new parts and air locker)
-New U-bolts all around
-Front Trac bar kit
-All new brake lines for 6” lift
-Sway bar links for 6” lift
-NV271 Transfer case
-5r110 shaft adapter
-Transfer case shifter
-Differential vents and breather hoses
-New Drag link end
-New Pitman arm
-Fuel tank shortening kit
-Raceline 17x9 Black wheels x5
-Toyo Open Country R/T 35x12.5-17 tires x5
Body
-Fender flares
-Rhino line fender flares
-Rhino line rockers
-Rhino line grill
-New Ford emblem
-New headlights housings and vinyl covers
-LED headlight bulbs
-Aluminess front bumper w/ 4 Rigid dually LED lights
-Heavy duty d hooks with rubber Isolators
-Warn VR12000 Winch
-Synthetic winch rope
-Aluminess rear bumper w/ tire carrier and storage box and hella reverse lights
-Rockslide Engineering rock sliders with electric drop down steps on both sides
-Tinted windows
-Weather tech window vents
-Weather tech hood deflector
-CR Lawrence fixed windows added to side barn doors
-CR Lawrence window with twist open vent added to driver side
-Custom 6.0 Powerstroke badges added
-Stubby antenna
Camper conversion
-Colorado camper van Tall POP-top installed w/ MaxAir fan, LED interior lighting, two 1000lb electric actuators with wall switch and remote to raise and lower. Top was upgraded w/ insulated canvas and has 6 windows with clear windows and screens. Also has 4 moveable bed panels and cushions for multiple setup configurations
-Entire floor and wheel wells painted with ceramic heat/sound blocking coating
-Single layer of thermozite on floor and walls
-Single layer of cork padding on floor
-7-ply cabinet grade plywood sub floor
-All walls and door panels made from wood paneling and carpeted
-1800 watt inverter running two standard GFCI house plugs and has plug in for shore power
-Two 100watt Renogy solar panels on the roof controlled by Renogy Rover 40a controller
-400 AGM “house” battery underneath in skid plate
-Six USB plugs in van ( 4 down and 2 up in bed area)
-All custom cabinetry w/ cabinets, drawers and under bench storage
-Locking knobs on all cabinets
-Butcher block counter top
-Stainless bar sink with custom electric water pump and 5gal jerry can
-Single burner induction cook top
-Isotherm stainless fridge w/ small freezer
-Stain master for pets padding and carpet
-Toyota Sienna leather front seats
-Swivel base on passenger side w/ recliner seat
-Stowable table post and table top
-Long pass through storage accessible from rear barn doors
-Custom Kenwood stereo w/ Apple car play, kenwood speakers all around and kicker amp and subwoofer
-Custom door gallery added to side barn door for storage and outdoor cooking
Gride7
More Pictures
Gride7
More pictures 2
Gride7
More pictures 3
JSF
Does the camper pop up? If so any pictures would be very helpful.
The engine can't run on high sulfur diesel correct since it's after 2006? Want to be able to travel through Mexico and South America thank you.
Gride7
I am not sure about the high sulfur diesel so I’d have to check.
Attached are some pics with the top popped.
Gride7
PRICE DROP to $85k OBO
Haven't had time to use the van much this summer so it has been stored away in the garage. However I did have a few things done in anticipation of getting to use it more. The list of things that was just completed follows:
-New Turbo solonoid
-6.0 blue spring upgrade
-Full coolant flush and new coolant
-New Alternator (voltage readings were starting to get a bit erratic so just installed a new one to be safe)
Please message me with any questions or offers as I would be happy to answer.
4xCoffee
